Kellaway's Fabia VRS
Looks lovely, spotted you parked outside the cop shop this afternoon, very tidy.
Cheers Buddy. I'm in Catterick most days so will keep an eye out for you in your Monte!
  • Replies 149
  • Views 27.4k
  • Well it rained last night. Looks like the Gtechniq C2 - Liquid Crystal v3 did a cracking job! Look at these beeeeeds!
  • Moved on to the other side and luckily its much easier, had the strut out in about 15mins. IMG_7379.jpg by Daniel Kellaway, on Flickr IMG_7380.jpg by Daniel Kellaway, on Flickr IMG_7381.jpg by D
  • So the car has gone from this. IMG_6404.jpg by Daniel Kellaway, on Flickr To this, IMG_7468.jpg by Daniel Kellaway, on Flickr IMG_7470.jpg by Daniel Kellaway, on Flickr The handling has
So been doing a few more bits to the Fabia over the last few weeks.
Had new Lemforder track rod ends fitted and tracking re-aligned, didnt bother doing this my self as the garage chucked the track rods on for free with the alignment :)
The old ones where pretty loose and looked original, sorry no pics this time!
Next up was the lower ball joint and the fitting PSB Polly Bushes to the lower arm to fully finish off my suspension refresh!
Started off with the usual, cleaned the garage out and got the car in and up on stands!
29232104511_90384963f1_b.jpgIMG_8008.jpg by Daniel Kellaway, on Flickr
New Goodies.
29310782035_2b57b28c43_b.jpgIMG_8009.jpg by Daniel Kellaway, on Flickr
28689973313_b208d11720_b.jpgIMG_8010.jpg by Daniel Kellaway, on Flickr
29202659332_4f16140187_b.jpgIMG_8014.jpg by Daniel Kellaway, on Flickr
Old Ball joints, Yum
29022888190_c8545c1637_b.jpgIMG_8016.jpg by Daniel Kellaway, on Flickr
Whole arm
28689990753_c2e3dbd8eb_b.jpgIMG_8018.jpg by Daniel Kellaway, on Flickr
Nut removed with a fight!
29022893950_052b74b700_b.jpgIMG_8020.jpg by Daniel Kellaway, on Flickr
Now, the main lower arm bolt on these is well known to be stuck solid and break off inside of the lower console sub frame, mostly due to the miss match of steel bolt in a aluminium casting. I was fearing the worst so had purchased two new lower consoles from ECP for £117 and some new bolts from TPS in case mine where to break so i wasn't stuck car less.
Gave the bolts a good soak in Plus Gas, I've never used Plus Gas before but had heard good reviews and i wasn't disappointed.
So with some praying and a few love taps with the big hammer before i even tried to remove them, i stuck the impact on them and went for it. To my wallets surprise and delight they came flying out!
28690002363_160b720041_b.jpgIMG_8022.jpg by Daniel Kellaway, on Flickr
Looks like when the console bushes have been changed in the past the lovely mechanic who did the job gave the bolts a good coat of anti-seize :D If i could buy that man a beer i would!
Grabbed the pickle fork to break the lower ball joint tapers.
29276927476_efe7bed1fd_b.jpgIMG_8024.jpg by Daniel Kellaway, on Flickr
29022905900_785884d19f_b.jpgIMG_8026.jpg by Daniel Kellaway, on Flickr
Removed from the hub, Ball joint had quite a bit of free play in it on the passengers side.
29202678692_90dcd8b3df_b.jpgIMG_8027.jpg by Daniel Kellaway, on Flickr
After some rotating the arm and some swearing the arm was free.
29232131841_4060d349d2_b.jpgIMG_8028.jpg by Daniel Kellaway, on Flickr
In the vice for ball joint removal.
29276943326_3150aa5712_b.jpgIMG_8029.jpg by Daniel Kellaway, on Flickr
29276946856_10e11acdc0_b.jpgIMG_8033.jpg by Daniel Kellaway, on Flickr
28690015313_2fe0cfef7c_b.jpgIMG_8034.jpg by Daniel Kellaway, on Flickr
Got the drivers side pulled out and found the ball joint was split and very loose.
28690019823_61c3d76e62_b.jpgIMG_8035.jpg by Daniel Kellaway, on Flickr
29202692472_7226319846_b.jpgIMG_8036.jpg by Daniel Kellaway, on Flickr
Now on to removing the front smaller bushings.
Cut the excess rubber off then with a combination of m12 threaded road and some sockets push the old bushings out.
28688203904_fd3719fb6d_b.jpgIMG_8037.jpg by Daniel Kellaway, on Flickr
29022932760_30efb4bdd5_b.jpgIMG_8038.jpg by Daniel Kellaway, on Flickr
29310816555_de395d4bb5_b.jpgIMG_8039.jpg by Daniel Kellaway, on Flickr
29022939410_c9b897d09e_b.jpgIMG_8040.jpg by Daniel Kellaway, on Flickr
29202705642_e24e719131_b.jpgIMG_8041.jpg by Daniel Kellaway, on Flickr
28688212834_1ff273d277_b.jpgIMG_8042.jpg by Daniel Kellaway, on Flickr
Both bushes removed and lower arms ready for a quick clean up.
29310822845_f0a7c2eb3e_b.jpgIMG_8043.jpg by Daniel Kellaway, on Flickr
29310825665_7ab5771926_b.jpgIMG_8044.jpg by Daniel Kellaway, on Flickr
Couple of coats of zinc primer followed by some matt black.
29310827715_6ce3f27c9a_b.jpgIMG_8045.jpg by Daniel Kellaway, on Flickr
So the old console bush.
29022957360_f301422b5a_h.jpgIMG_8047.jpg by Daniel Kellaway, on Flickr
Removed with a combination of hacksaw and chisels.
28688228684_90a38a92de_h.jpgIMG_8048.jpg by Daniel Kellaway, on Flickr
29202723852_728e4a96b6_h.jpgIMG_8049.jpg by Daniel Kellaway, on Flickr
29232148671_666c90ddfa_h.jpgIMG_8050.jpg by Daniel Kellaway, on Flickr
Old V New
29310837635_314aeb0f10_h.jpgIMG_8051.jpg by Daniel Kellaway, on Flickr
Tapped in.
29276997296_3e95e87c34_h.jpgIMG_8053.jpg by Daniel Kellaway, on Flickr
Quick photo of the new track rod ends while im here.
29310840565_ae2f76a3e4_h.jpgIMG_8056.jpg by Daniel Kellaway, on Flickr
Arms ready to go.
28688240464_118dde0e0d_h.jpgIMG_8057.jpg by Daniel Kellaway, on Flickr
Installing the front bush.
28690065493_ac9f465cc2_h.jpgIMG_8059.jpg by Daniel Kellaway, on Flickr
29202740962_fd4f013dbc_h.jpgIMG_8060.jpg by Daniel Kellaway, on Flickr
29202744442_0144ef09b3_h.jpgIMG_8061.jpg by Daniel Kellaway, on Flickr
29232162341_19dee41f63_h.jpgIMG_8063.jpg by Daniel Kellaway, on Flickr
Reinstalling new ball joint.
29022985340_0da65ccd2c_h.jpgIMG_8065.jpg by Daniel Kellaway, on Flickr
29310850995_886223978a_h.jpgIMG_8067.jpg by Daniel Kellaway, on Flickr
Ready to go.
28688256584_7ea4e10949_h.jpgIMG_8068.jpg by Daniel Kellaway, on Flickr
New M12 bolts.
28688258714_1d7f47ddb2_h.jpgIMG_8069.jpg by Daniel Kellaway, on Flickr
After some fighting and swearing got the lowers arms back in and bolted up. Took some hammering and aligning but got the job sorted.
29022997420_18ab396e22_h.jpgIMG_8070.jpg by Daniel Kellaway, on Flickr
29277024426_f13467da97_h.jpgIMG_8072.jpg by Daniel Kellaway, on Flickr
29277026476_fdc032a30e_h.jpgIMG_8073.jpg by Daniel Kellaway, on Flickr
Got the wheels back on and went for a drive, massive improvement yet again. Alot more precise turn in and not as much wondering around on the road! Well worth the time and money!
Nice job, will be doing the same on my when its time for winter tyres.
Nice attention to detail there pal
I've got to say, im surprised someone like you didnt just replace the bottom arms, i picked up two new arms with ball joints and bushes for £40 on ebay, since you were replacing the bushes anyway it wouldnt have made much difference.
Ive been burned in the past with cheap lower arms. I was on the look out for some febi or lemforder arms to pop up for a reasonable price but couldnt find any. Wanted to polly bush the whole arm. Hopefully going about it this way i wont have to change the ball joints again.
The ones i got were Febi, so i was pleased! very lucky to get them mind.
  • 2 months later...
Small update, been trouble free motoring for the last few thousands miles, just general keeping the VRS clean and getting out and using it!
As the cold nights started coming in i noticed the battery becoming ever so weak, considering its the original battery at 9 years old its time for a change!
New Exide EA640 4 Year warrenty 64Ah with 640CCA! - £48 delivered next day bargain! Euro Car Parts wanted over £75 for the same battery!
30289530464_b55e8fad1f_h.jpgIMG_8461.jpg by Daniel Kellaway, on Flickr
Whipped the old one out in the freezing cold due to my garage having a family members car in for repair!
30955781142_b5f6df653a_h.jpgIMG_8462.jpg by Daniel Kellaway, on Flickr
9 Year old original!
30731023850_7132599f3b_h.jpgIMG_8463.jpg by Daniel Kellaway, on Flickr
Installed in its new home!
31062233296_065001cb81_h.jpgIMG_8465.jpg by Daniel Kellaway, on Flickr
Jumped in the car and wow, i hadn't really noticed how bad the old battery had got! Engine jumped to life extremely fast!
Should see me right for winter!
Great updates! Keep them coming
Thats what i thought when i replaced mine, it actually transformed the car when starting on cold mornings.
No more sluggish turning over with a puff of smoke out the back, just turn the key and get an instant start.
Yup, mine was starting to get very smokey on start up and it's now as clean as a whistle. Yup it's crazy how fast they start with a new battery!
So been 12k miles and a year of motoring out of the VRS, she is due for an MOT and service.
32123526402_341d498998_b.jpgIMG_0415.jpg by Daniel Kellaway, on Flickr
So took her down the local Mot place, and she passed! however not with a clean sheet!
32123523412_ae3b555e0b_b.jpgIMG_0412.jpg by Daniel Kellaway, on Flickr
The tyres are going to be a easy fix, knew they were getting low.
The Cv Boot was not expected, and its getting sorted ASAP. Dont want water and crap getting in the joint!
The only oil leak ive been able to find is the lower inter cooler pipes have a slight weep on them. Noting to worry about and a quick clean will be fine.
The exhaust clamp, yet again. Easy Fix.
So went and grabbed some parts!
32153200021_9d89d48b1a_b.jpgIMG_0408.jpg by Daniel Kellaway, on Flickr
31896383050_f0ba967249_b.jpgIMG_0429.jpg by Daniel Kellaway, on Flickr
31896384460_133e08b74d_b.jpgIMG_0430.jpg by Daniel Kellaway, on Flickr
Then got her home and in the garage and up on axle stands!
32123530892_173df6aeb6_b.jpgIMG_0418.jpg by Daniel Kellaway, on Flickr
First up was oil and filter change!
32123532842_d8b7a7c675_b.jpgIMG_0420.jpg by Daniel Kellaway, on Flickr
32123533902_fe9e4fbaf3_b.jpgIMG_0421.jpg by Daniel Kellaway, on Flickr
31896378350_b999df8dfb_b.jpgIMG_0423.jpg by Daniel Kellaway, on Flickr
Then air,
31896386490_bc0dc8d396_b.jpgIMG_0432.jpg by Daniel Kellaway, on Flickr
32234299256_c6c266e299_b.jpgIMG_0434.jpg by Daniel Kellaway, on Flickr
Pollen filter, which wasnt to bad to be honest, but changed anyway.
32234301396_9892ce6d10_b.jpgIMG_0435.jpg by Daniel Kellaway, on Flickr
32234303926_87734c03ea_b.jpgIMG_0436.jpg by Daniel Kellaway, on Flickr
Sorted the exhaust clamp, was past its best haha!
32234306826_8d4cc83a64_b.jpgIMG_0439.jpg by Daniel Kellaway, on Flickr
31896398770_4a1d0a2a4c_b.jpgIMG_0442.jpg by Daniel Kellaway, on Flickr
Replaced with a new ECP special!
32153242451_781cba462e_b.jpgIMG_0444.jpg by Daniel Kellaway, on Flickr
Going to sort the CV boot over the weekend, just waiting on a 36mm 12pt Bi-Hex socket to be delivered off Amazon. I've got a pretty decent selection of tools, but always seem to need more :D
Edited by kellaway86
CV Boot Fix Part 1
So decided to go get a genuine CV Boot so nipped to TPS and picked up one, and took the other one back to ECP, Not worth the risk of having to do the job twice!
31512111324_e3a503950f_b.jpgIMG_0445.jpg by Daniel Kellaway, on Flickr
Also got a new 36mm 12 point socket from amazon for the hub nut!
32234297271_e93eda1292_b.jpgIMG_0446.jpg by Daniel Kellaway, on Flickr
32234299071_5b1a926468_b.jpgIMG_0447.jpg by Daniel Kellaway, on Flickr
So got "my assistant " to hold the break for me while undoing!
31977642420_f9392cbc79_b.jpgIMG_0450.jpg by Daniel Kellaway, on Flickr
Once that's removed next is the 3 x 13mm bottom ball joint bolts!
32354451375_6569b472df_b.jpgIMG_0454.jpg by Daniel Kellaway, on Flickr
Next up the 6 x M12 spline bolts on the drive shaft, easy removal with the air ratchet!
32354453665_1ec06bb928_b.jpgIMG_0457.jpg by Daniel Kellaway, on Flickr
Give the shaft a knock or two and you have your self 1 x driveshaft!
32354455655_29d40e88c7_b.jpgIMG_0459.jpg by Daniel Kellaway, on Flickr
Split boot.
32354457385_957aa9b163_b.jpgIMG_0461.jpg by Daniel Kellaway, on Flickr
Cut the boot open and put some gloves on! Its going to get messy!
32204382222_8b3d905b0f_b.jpgIMG_0464.jpg by Daniel Kellaway, on Flickr
Yummy
32204383822_7ddaa468a8_b.jpgIMG_0465.jpg by Daniel Kellaway, on Flickr
32204385802_8b550e2008_b.jpgIMG_0466.jpg by Daniel Kellaway, on Flickr
After using an entire roll of paper towel.
32204387652_c66bb16d8b_b.jpgIMG_0467.jpg by Daniel Kellaway, on Flickr
Proceed to knock the knuckle off the shaft! Lump hammer required here as the ball peen not man enough!
32204389742_1500449a2c_b.jpgIMG_0468.jpg by Daniel Kellaway, on Flickr
Knuckle Removed.
32204391872_b1b4893c58_b.jpgIMG_0469.jpg by Daniel Kellaway, on Flickr
32315412756_e5daa84ce8_b.jpgIMG_0472.jpg by Daniel Kellaway, on Flickr
Given a proper clean.
32354475235_4bb1688b30_b.jpgIMG_0473.jpg by Daniel Kellaway, on Flickr
Cleaned up with the wire wheel and masked for painting!
32234338181_0b0a8b16bf_b.jpgIMG_0475.jpg by Daniel Kellaway, on Flickr
Primer then top coat!
31543404693_be62b1ca3c_b.jpgIMG_0479.jpg by Daniel Kellaway, on Flickr
Leaving that to dry over night and will put it back together tomorrow!
EGR Delete / Blank / Manifold Clean
So Ive decided to blank off the EGR and give the inlet and ASV a good clean. Im sure its due after 125k miles!
BLT Engine EGR Setup
31543409093_ec62c99e55_b.jpgIMG_0480.jpg by Daniel Kellaway, on Flickr
Remove the elbow,
32354483105_0fc9db3fce_b.jpgIMG_0483.jpg by Daniel Kellaway, on Flickr
Sign of things to follow, ASV looking "clean"
32315422766_af11c32dd5_b.jpgIMG_0482.jpg by Daniel Kellaway, on Flickr
ASV removal
31543419833_581f17a7dd_b.jpgIMG_0485.jpg by Daniel Kellaway, on Flickr
Some nice pesky hidden bolts!
31543421173_7b85c5e9f2_b.jpgIMG_0486.jpg by Daniel Kellaway, on Flickr
O boy! The ASV!!
31977688090_c3fae45d53_b.jpgIMG_0492.jpg by Daniel Kellaway, on Flickr
31543425033_545abef02e_b.jpgIMG_0493.jpg by Daniel Kellaway, on Flickr
The EGR!!
31543426793_b5f8e4bdde_b.jpgIMG_0498.jpg by Daniel Kellaway, on Flickr
Inlet not looking the best!
31543429173_8f2dea361f_b.jpgIMG_0500.jpg by Daniel Kellaway, on Flickr
Turbo Inlet Pipe removed!
31543431213_de47d0f28f_b.jpgIMG_0502.jpg by Daniel Kellaway, on Flickr
BLT Euro 4 EGR Cooler removal! Had some right pain in the ass bolts to remove!
31543433003_b65f2176a3_b.jpgIMG_0504.jpg by Daniel Kellaway, on Flickr
Finally the Inlet manifold removed!
31543435783_e898c2dcf4_b.jpgIMG_0506.jpg by Daniel Kellaway, on Flickr
32315445106_4276413070_b.jpgIMG_0510.jpg by Daniel Kellaway, on Flickr
Bit Choked up!
32315448056_1a804c0a6d_b.jpgIMG_0511.jpg by Daniel Kellaway, on Flickr
Next drained the coolant so i can remove the EGR Cooler!
32315450926_ccf287df3d_b.jpgIMG_0512.jpg by Daniel Kellaway, on Flickr
31512185544_58ba20439b_b.jpgIMG_0515.jpg by Daniel Kellaway, on Flickr
Then take out on of the coolant pipes and loop it into the "T" to complete the circuit!
32315457076_f4de244e56_b.jpgIMG_0516.jpg by Daniel Kellaway, on Flickr
32315459656_8ce14c63a1_b.jpgIMG_0517.jpg by Daniel Kellaway, on Flickr
That's as far as i got tonight, blanking plates should be here tomorrow, and already picked up new gaskets and O rings from TPS.
Going to be doing a bit of DIY ECU tinkering as well as blanking the EGR will throw the EML on.
Think she going to drive alot better with all that crap cleaned out!
Got a bit more work completed today before work.
Decided to tackle all the dirty jobs today and get every thing cleaned up ready to go back together.
All started with fire!
32372424955_739af9cffb_k.jpgIMG_0518.jpg by Daniel Kellaway, on Flickr
A very dirty inlet about to get a good "bath"
32252192021_6847665435_k.jpgIMG_0521.jpg by Daniel Kellaway, on Flickr
32372430025_1350745d3d_k.jpgIMG_0520.jpg by Daniel Kellaway, on Flickr
Fire + compressed air = Clean manifold!
Here is the Youtube video of it on fire :D https://youtu.be/7yy7m6XdkkI
31529861824_b1eb5b14c9_h.jpgburn1.jpg by Daniel Kellaway, on Flickr
31529863964_97331a015d_h.jpgburn2.jpg by Daniel Kellaway, on Flickr
After burning, some dry carbon remains.
32252193941_3b75b4dc7e_k.jpgIMG_0525.jpg by Daniel Kellaway, on Flickr
32252196111_172e4fe585_k.jpgIMG_0527.jpg by Daniel Kellaway, on Flickr
Got the Egr and ASV cleaned out, with a combination of chemicals and scrubbing!
31995212680_2921f83a17_k.jpgIMG_0532.jpg by Daniel Kellaway, on Flickr
32252200741_f6ee85cea8_k.jpgIMG_0533.jpg by Daniel Kellaway, on Flickr
32252204451_9a0569789d_k.jpgIMG_0535.jpg by Daniel Kellaway, on Flickr
32222198592_e8b2326a12_k.jpgIMG_0536.jpg by Daniel Kellaway, on Flickr
Set about giving the manifold and the turbo inlet pipe a good clean!
The finished product!
32222201192_88920ad704_k.jpgIMG_0540.jpg by Daniel Kellaway, on Flickr
31561343493_63342f39c1_k.jpgIMG_0542.jpg by Daniel Kellaway, on Flickr
31561344873_8b86f2e935_k.jpgIMG_0544.jpg by Daniel Kellaway, on Flickr
32222212782_206f5ac0e0_k.jpgIMG_0545.jpg by Daniel Kellaway, on Flickr
31561347123_021c4a5bf0_k.jpgIMG_0546.jpg by Daniel Kellaway, on Flickr
Next moved onto sorting the CV Boot
Unmasked.
32222199982_e8f0631b9d_k.jpgIMG_0537.jpg by Daniel Kellaway, on Flickr
New boot on,
32252235951_c56c41a2d8_k.jpgIMG_0550.jpg by Daniel Kellaway, on Flickr
No pictures of the during, didn't want to get new CV grease all over the place!
32252238001_012e89ed02_k.jpgIMG_0553.jpg by Daniel Kellaway, on Flickr
Next dirty job was change the leaking rocker cover gasket, it had been seeping down the back of the engine.
32222223582_7a8ebad347_k.jpgIMG_0554.jpg by Daniel Kellaway, on Flickr
Removed
32252242521_8ad3b77929_k.jpgIMG_0556.jpg by Daniel Kellaway, on Flickr
Here is where it had been leaking.
31995245250_80c1edcd68_k.jpgIMG_0561.jpg by Daniel Kellaway, on Flickr
And here,
31995249090_6470bea560_k.jpgIMG_0562.jpg by Daniel Kellaway, on Flickr
New one getting put in place, not many pics as you have to use some sealant! You use a couple of spots of sealant and then place the cover back on the head them torque down the 13 bolts in a pattern to 10NM.
Cambelt looked in good condition!
32333374736_b62dcd2ae6_k.jpgIMG_0564.jpg by Daniel Kellaway, on Flickr
Thats it for today, got the rocker cover back on, and cleaned up the massive mess i had made. Hopefully next few days will get it all put back together!
Good updates as usual.
The BLT EGR valve setup is a right chew to remove isn't it :D
As for the carbon build up, it's just like have restrictor plates fitting across the inlet manifold! Much better to get them removed.
The EGR/ASV wasn't as bad to remove as i was expecting, it was the god damn EGR Cooler that i wanted to smash up with a hammer! Yer once its back together its got to run alot better without all that crap restricting airflow!
Great job :)
Love the flaming of the inlet! Where did you get that idea?
One thing I would have done whilst cam cover/EGR was off is bang in a set of PD150 headbolts
Seen the flaming of the inlet on youtube, works a absolute treat!
Update.
So the EGR blanking plates finally got delivered, some nice 3mm think ones with new gaskets.
32398584586_8f2023db36_b.jpgIMG_0565.jpg by Daniel Kellaway, on Flickr
Blanking the manifold end.
32438472765_ba4bdacce1_b.jpgIMG_0567.jpg by Daniel Kellaway, on Flickr
32060512310_dc7aefae9a_b.jpgIMG_0568.jpg by Daniel Kellaway, on Flickr
Then the EGR End. Had to use new M6 bolts with some extra nuts and spacers to take the slack.
31626897143_18ab4280f8_b.jpgIMG_0571.jpg by Daniel Kellaway, on Flickr
31626898683_bacbe7e4bc_b.jpgIMG_0572.jpg by Daniel Kellaway, on Flickr
Next up was replace the Inlet manifold, new genuine gasket used.
31626908103_ce89394191_b.jpgIMG_0579.jpg by Daniel Kellaway, on Flickr
Installed, looking alot cleaner!
32438490505_7a991ea754_b.jpgIMG_0583.jpg by Daniel Kellaway, on Flickr
Next up turbo intake pipe.
32060527080_4370c04b3c_b.jpgIMG_0585.jpg by Daniel Kellaway, on Flickr
Had to use a jubilee clip instead of the spring clip as it was in a nightmare location!
Installed.
32060531170_c86bd28f97_b.jpgIMG_0587.jpg by Daniel Kellaway, on Flickr
Got all the EGR and ASV bolted back on and the boot pipes reinstalled.
32438500025_23ff63a112_b.jpgIMG_0588.jpg by Daniel Kellaway, on Flickr
Next up was just the quick job of putting the driveshaft back in.
First off get the driveshaft back in the hub and re tighten the lower wishbone bolts.
31626900683_5acf184b08_b.jpgIMG_0573.jpg by Daniel Kellaway, on Flickr
New nut a must.
31595282464_ed83b0635a_b.jpgIMG_0576.jpg by Daniel Kellaway, on Flickr
Tightened to 70NM then 45 degrees = tight!
32398595906_361bd57543_b.jpgIMG_0577.jpg by Daniel Kellaway, on Flickr
Jack up lower arm to enable you to install the remaining 6 spline bolts dune up and torqued to spec.
Finished, no more nackard CV Boot.
31626906843_85ab1a9b04_b.jpgIMG_0578.jpg by Daniel Kellaway, on Flickr
So got the engine undertray back on and topped the fluids back up and went for a drive!
WHAT A DIFFERENCE!! So much more responsive and feels so much smoother!
How ever as expected, the EML is now on in the dash. Will be sorting that in the next update!
Not sure the paper gasket on the turbo end will last very long, should be the metal gasket iirc!
Good work again though :thumbup:
Yer, will keep an eye on the paper gasket!
Engine Management Light - The Fix.
31598962314_d20a5d562f_b.jpgIMG_0589.jpg by Daniel Kellaway, on Flickr
So after a lot of research i dragged my computer down to the garage, got the car pulled in hooked up via a cheap Chinese MPPS cable!
32291027412_4b390b04b9_b.jpgIMG_0595.jpg by Daniel Kellaway, on Flickr
32064261760_899433dac4_b.jpgIMG_0610.jpg by Daniel Kellaway, on Flickr
Fired up the MPPS software and it connected right away.
32321147081_7d142f661a_b.jpgIMG_0597.jpg by Daniel Kellaway, on Flickr
Downloading a copy of the cars map.
32064250840_6d63935eba_b.jpgIMG_0600.jpg by Daniel Kellaway, on Flickr
Little bit sketchy i know!
32442199135_1a66ab52e2_b.jpgIMG_0601.jpg by Daniel Kellaway, on Flickr
Once it had finished downloading the map, i set about editing the EGR codeblock.
32064255100_525c2f0470_b.jpgIMG_0602.jpg by Daniel Kellaway, on Flickr
The theory here is to flatten the block so the ECU is not longer requiring the air flow that the EGR would have been adding.
32064256300_bd4f08ccbf_b.jpgIMG_0604.jpg by Daniel Kellaway, on Flickr
Once that was sorted, you save the map ready for re-flashing to the car.....
The scary, no going back question!
32064259150_624591f40f_b.jpgIMG_0606.jpg by Daniel Kellaway, on Flickr
Followed by 3mins of terror, hoping not to brick the ECU!
32064260290_8191e44144_b.jpgIMG_0608.jpg by Daniel Kellaway, on Flickr
Pleased to report that the flash went fine and the car jumped to life!
Last job was to clear the DTC code for the EGR via VCDS.
32321157821_9a886a2de9_b.jpgIMG_0612.jpg by Daniel Kellaway, on Flickr
With the fault cleared, it was time for a test drive!
Im very pleased to report that after 20miles the EML has not returned! So bit of DIY mapping success!
Now that is quite impressive really!
I've got the software but never attempted to mess around with the mapping, good little guide you've put up really :D
I'd like to try that on my MK2 as the light has came on since blocking the EGR valve, sadly I think my ECU needs to be removed and modified in some way before you can edit the software
Just looked online for this and it doesn't support the Mk 2 with the 1.6 tdi? I will keep looking as I'd love it off for egr too.
Very impressed with DIY mapping. Well done sir !!
Edited by Richard92
Just looked online for this and it doesn't support the Mk 2 with the 1.6 tdi ???????? I will keep looking as I'd love it off for egr too.
Sadly not, the ECUs are locked really...
One of the downsides to newer software I guess! It hasn't been messed around with as much.
