Milltek Exhaust Group Buy
Very nice indeed...nice to see there none of that flexi-joint stuff either.
How are you getting on with the inlet gasket? Haven't fitted mine yet.
You'll have to post some pics of your custom system.
  • Replies 78
  • Views 7k
Thanks.
Yes, no flex part, but another kind of joint which the Greek custom exhaust makers use in downpipes in order to absorb vibrations.
You can have a look at my turboback system here
The gasket - I think it's doing a very good job. Loukas has also fitted it, he's got vagcom and we are going to make some tests ... But the fact is that now you can touch the intake manifold, after a hard run, which is just hot and not burning !
Unfortunately we're now not in a position to qualify for the 20% discount as we have "lost" 4 items so' date=' I am going to "close down" this group buy attempt.
Thanks for all those who expressed an interest. I may try to resurect this again sometime next year, pending interest.
Cheers.
Adrian.[/quote']
Adrian,
If you do try for the group buy next year, you can put my name down as a definite - not sure whether cat back / full system though?
Keep up the good work! :thumbup:
Andy
Andy,
whether you go for sports dp/cat or cat back or both depends on what you want to achieve. If it just for a bit of style and sound then cat back is fine. The are a few cat back choices...Milltek, Jetex, Supersprint etc.
If you want some performance gains then get the sports dp/cat AND cat back. The Milltek is the only sports dp/cat available I believe (unless you want to go the whole decat route). This obviously fits the Milltek cat back or the Jetex cat back.....which I have.
Turbo seems to spin up quicker and pulls much better, particularly higher up. It will get better once I've done 60 or mile sof normal driving (non motorway) and the adaption sorts it self out. The exhaust is a little deeper and now gives a hard edge to the exhaust note when accelerating from 80mph upwards...on a private track of course. ;)
Suppliers and fitters as the usual suspects. I had Jabba supply and fit both parts of the complete system. I had the cat back done first. This may be the route you choose to do first...it's easier on the pocket.
If you want to discuss more jsut PM me.
Cheers.
Adrian.
