Moan about bulbs....
... or more to the point, WHY DO THEY PUT THE NEARSIDE FRONTS SO CLOSE TO THE DAMNED BATTERY BOX... :mad:
... and.... breathe....
As you can probably tell, after only 2 weeks of having the offside dipped blow (nice easy replacement, loadsa room) - the nearside blew on Xmas eve! :grumpy:
Took me longer to ease the cover outta there, than it took me to do the whole swap on the offside, :rolleyes: Just everything's so damned tight down there with the battery box being in the way.... Hate it!
Hope this bulb lasts longer though. :)
At least you dont have a MK2 mondeo. I had the joys of changing a headlight bulb a week ago. To change that you need to remove the whole headlight, which in turn involves removing the radiator grill, so a simple job means undoing 6 screws and stripping of skin from knuckles just to change a bulb.
moan, moan, moan :rolleyes:
Get somebode else to do it :)
If I had a SWMBO to do it, I wouldn't even force that task upon her. :) Would be the end of that relationship. :rofl:
Was OK in the end, just seems silly....
It's a pain, I've been testing some quad-LED sidelight bulbs and they seem to blow regularly (given up now, gone back to standard!). I found it easiest if you remove the top and side battery box covers, adds about two thirds of an inch to move - not much, but makes it a bit easier.
Although in the design phase the bulbs are probably not even considered for ease of replacement, I think this stinks. :mad: The same is with most cars nowdays. You break down and need to replace a bulb. (remember the days when you bought a bulb kit) I think the designers are missing the basics. Moan,moan,moan. :D
I'm still puzzled with how I'm going to fit my new bulbs in the xenon units.
Is there any issues with removing the headlight? Will it need adjusting afterwards?
And J - make sure you don't drop the headlight cover in any gearbox cables! ;):rofl:
Sorry - someone had to! :rolleyes:
Use the single led bulbs, i had the same trouble with the quads, but the singles are great.
Beat me to it :rofl:
A thought.... remove the headlight theres just two screws holding it on at the top (as i found out yesterday.... one had become worringly lose!)
:finger::D
You do NOT know how well I check those covers are attached once a bulb change is done! ;) I must shake the thing for 30 seconds to make sure nothing will make it come loose again. :D
Or in my case, break the grill as the screws had seized!! :thumbdwn:
You on the Mondeo forums??
Or in my case' date=' break the grill as the screws had seized!! :thumbdwn:
You on the Mondeo forums??[/quote']
Just try it on a V6 diesel Signum. I managed to do the dip beams, but I'd lost too much blood to go onto the mains!
Phil
Seems like a 'jobs for the boys' thing - the home mechanic is unfortunately a dying breed and the stealers make more money.
OctyII is dead easy. undo a plastic wing nut thingy, pull a lever and withdraw the headlight. Then take it into the warm confines of the house to do the work.
Renault Megane II is a different story. You need a double jointed monkey armed with a pair of pliers and a screwdriver to change the lamps in one of those and there's no guarantee he'll make it back alive so you might lose your deposit.
Much easier on the Mk3 - took me 5 minutes to change both dipped, main and sidelight bulbs and came out the other side completely unscathed :D
Chris
