VCDS Light Assist Mod Not Working
What version of VCDS are you using?
Latest 15.7.4
This is what an auto-scan afterwards gives me:
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: Malfunction 0010
A5-Frt Sens. Drv. Assist -- Status: Malfunction 0010
A9-Struct. Borne Sound -- Status: OK 0000
Edited by skipptg
nobody else tried this or had an issue?
Latest 15.7.4
When was your car built? 15.7.4 was released in February, so may have newer software than the release.
Try using the Beta (16.7.0)
Ok tried the beta with a firmware upgraded cable, same result.
I completed this mod on MY16 car for another member recently with no problems. Used the Beta version of VCDS and did indicator no. of flashes mod at the same time so had to reset the factory light settings on the infotainment.
Try resetting the factory light settings via the infotainment to see if this cures:
Car >> Set up >> Factory Settings >> Lights. Reset using the prompts.
If this doesn't work, I would probably reverse all of the HBA / light assist settings back to stock and then re-try
If still having problems then post the adaptations log, so that members can see which coding has been changed.
Thanks - am going to give this another go now. I reset everything back to how it was last night.
Since I updated to the beta version I noticed another adaptation had appeared relevant to this procedure:
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung
The first one is the one listed in the instructions, but what does the 2nd one mean? Something to do with factory setting if my rubbish German is corect. Should this be used instead?
Ok tried again, with a factory reset on Lights afterwards.  Same fault.
Address 09,5Q0 937 086 AK,channel IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,adapted from,Not Present ,to,present ,
Address 09,5Q0 937 086 AK,recoded (Long Coding),from,0F001A42C24722FB07A04082B10C07280000000000000000000000000000,to,0F001B42C24722FB07A04082B10C07280000000000000000000000000000,(73430/790/12345),
Address A5,5Q0 980 653 G,recoded (Long Coding),from,0101000001030306000400000100010100,to,0101020001030306000400000100010100,(73430/790/12345),
hi
skipptg
did you get a fix for this, ive done it using obdeleven, all the settings are as they should be but it still comes up with light assist fault. done the reset and rep[eated it but still get the error
any ideas anybody?
John
any news chaps?
I will try to assist when I get a chance to view the log of a car that I completed this adaptation for previously (MY16 VRS) - however this will not be until mid-week.
brill many thanks
If its of any help (probably not) I did this mod on my MY16 a few weeks ago and got a light fault at first too. Went back over the instructions and realised I'd missed a step.
After changing the missing adaption to what it should be, she's all working now.
Edited by mabnz
hi Mabnz
which step?
John
I wrote the instructions and have done it on my MY16 car with no issues, the drop down menu in the coding bit has changed description compared to my MY14 car the screen shots are from.
The Bits & Bytes are the same though, might be worth checking that......
I think this was the step I accidentally missed, for what it's worth:
Go to controller 09 - Long Coding
Change Byte 2 Bit 0-2 to a value of 03 using the dropdown menu for models with Xenons.
I've tried multiple times, definitely not missed a step anywhere, and the same fault continues.
me too
Go back and read the instructions and do what they say, the coding above is incorrect. You have changed Byte 2 from 00 to 02, when it should have been changed to 01 by enabling bit 0.
Access Module A5
Go to Long Coding, change byte 2 Bit 0 to a "1"
Then clear the fault codes from 09 and A5. Make sure your light switch is turned to 'OFF' whilst you are making any changes.
Edited by andyvee
brill Andyvee
thanks
off to try it now
When you have coded module A5 have you selected the correct setting?  On all of the cars that I have successfully coded the, the long coding has changed the 6th number from a '0' to '1'.  Your coding has changed from '0' to '2'.
i.e. Address A5,5Q0 980 653 G,recoded (Long Coding),from,0101000001030306000400000100010100,to,0101020001030306000400000100010100,(73430/790/12345),
Andy beat me to it (again)! - was typing without refreshing the screen.
Edited by Black_Sheep
