Rear disc brake wear
On 06/10/2019 at 10:23, MartiniB said:
finally replaced all
ODO: 76600km
to Otto Zimmermann
Front Brake Discs (2pcs)
100.3300.20 ZIMMERMANN Audi Coat Z
(Original Nr: 1K0 615 301 AA)
Rear Brake Discs (2pcs)
600.3252.20 ZIMMERMANN VAG Coat Z
(Original Nr: 3Q0 615 601)
Front pads (4pcs)
25683.200.2 ZIMMERMANN
Rear pads (4pcs)
25009.165.1 ZIMMERMANN
Hey MartiniB
How does the discs and pads keep up for you? I am thinking to change them to the exact ones...
You had them on since last October:) any update?
  • Replies 132
  • Views 31.8k
  • If you want the brakes to last then try this:-   Take them apart once a year ( in the autumn is best ) and thoroughly clean and re grease them. I found that it was worth doing this even
  • Jimbbobw1977
    Jimbbobw1977
    Hello all, I've been following g this post with interest.. please be nice to me I don't own a Skoda Superb, I have a Mondeo MK5 Powershift. It's done 12k miles and is a year old and also has an elect
  • I'd like to see you try this with the electronic handbrake.
I upgraded mine to Brembo OE discs and pads. The factory discs are awful, plus I guess the rears get used more than you think by other systems such as Lane guidance / esp / parking brake etc
Can't say there is day and night diff,
but Zimmermanns looks better than stock, compare -
original Rear disc after 11k Km
Zimmermann Rear after 10k Km
20200703_Otto_Zimmermann_Rear_10kKm_01_25p.thumb.jpg.e9877c7dda8bade637ce0b1d09de4b47.jpg
front's are almost equal
orig.
Zimmermann
20200703_Otto_Zimmermann_Front_10kKm_01_25p.thumb.jpg.34d23176aa3604b83b01be2487d373f6.jpg
You may find your question in the workshop manuals, that you can download from cardiagn.com. There's a whole workshop manual for brakes. ;)
Note, in this wokshop manual dedicated to brakes (unless this is in the maintenance chapter, I have a slight doubt), you will also find the spec for discs and pads minimum thickness. Very useful for a quick check! ;)
Edited by Bap33
@Bap33 Thanks for the advice. I've got one disk that's heavily rusted just on the outside and has worn the corresponding pad right down so will have to replace the lot unfortunately.
@D402 Good tips have to be shared ;) !
