Octavia VRS Diesel Using Oil Occasional White Smoke ?
We have a 62 plate Skoda Octavia VRS DSG Diesel estate ex police car.
I have had it since Jan 2016 and got it with 103K miles on and full service history all good.
It has now done 113K and has just been serviced 1000 miles ago.
However it started to develop a smokey burnt oil smell about a week ago and every now and then for a short while has white smoke from the exhaust that quickly clears up again.
In one week and 500 miles it has gone from max to min on the dipstick and continues to smell and occasionally omit white smoke but there is no rhyme or reason to it when etc ?
Any ideas what this could be ?? Rings, Turbo, push rod seals ??
Ruari
Head gasket? Any emulsification on the oil filler cap or in the coolant expansion bottle?
Is the smoke much worse when you accelerate quickly?  That's a sure sign of worn valve stem seals or rings/bores, or even a broken ring.  A compression test would be useful.
Water and Oil do not contain any emulsion and no water used only oil - it is very strange last night I had two miles of white smoke then gone again for 300miles on varoius local and longer runs since then.
Cannot pinpoint it too high acceleration or warm or cold engine - just totally unpredictable ?
OK mechanic friend came out yesterday (I was not at home) and checked it over and put all his electronic diagnosis stuff on it and could find nothing wrong - it us using less oil now and the white smoke is less frequent now - when i say white it is definitely an oily smoke as you can smell the oil. But only comes for a short while, a few 100 yards or a couple miles then goes again ??
Is there any kind of valve might be sticking >> Mike the mechanic was thinking this way ??
Makes some sense maybe a vent from the rocker cover or sump direct to exhaust ??
At least it does not seem to be a broken engine yet and shluld not be at 113,000 miles
HELP ??
  • 2 months later...
Still needing help in this Topic as car still smoking but only very occasionally now and for less than 1/4 mile at a time. Does not use hardly any oil.
Seemed to improve after adding one of those bottles of diesel fuel engine cleaners ??
My mechanic thinks it could be a valve that occasionally sticks and causing the oil discharge / ****e smoke but he did not know which or what
Can anybody help please ??
From a quick Google search...
"In diesel engines, white smoke may signify fuel not being burned well enough due to an injection problem or air delivery problem."
Thanks using the diesel clean up additives seems to improve things but the problem returns every few thousand miles ?? :-(
Back in September when it was serviced who serviced it & do you know what oil they used,
did you do it or supply the Oil.
Have you changed this oil since then?
hi
  if its white smoke it could be oil leaking from turbo directly into exhaust when hot its white smoke
  if oil was leaking into combustion chamber it would be blue
  if overfueling it would be black.
  if its them oily smelly fumes as well might be worth checking inlet manifold and egr for blockage with carbon.
  • 4 years later...
My VRS 2011 Diesel is doing this now, did you find the cause?
