P0671, P0672, P0674, and P0101 after turbo change
Hi,
I have recently replaced my good faithful Octavia mk1 with a Octavia mk2, however the turbo failed on me with an embarrassing about of smoke.  The mechanic has replaced the turbo with a new turbo but I don't think he has replaced the turbo pipes.  After he called me to say it was done, he then called me again to say he was running the car and the belt had snapped.  He then rang me a couple of hours later to say he had replaced the belt.
I understood there was likely to be some oil to burn off so expected some smoke. However it didn't feel right either, it was and still is juddering, is still smoking and is down on power but not in limp mode and the MPG is really poor.  When I unplugged the MAF sensor, it stopped smoking, juddering and the MPG shot up.  I got a new MAF, plugged it in and the smoking, juddering etc came back.  I also decided to treat myself to a genuine ross-tech HEX-CAN, (totally new to VCDS so I have been trying to learn quickly) I have pasted the Self-Diagnosis log below.  I also noticed the Torsion value in group 4 was -2.5 which I believe is meant to be 0.
If anyone could give me any suggestions on what I should do to get my car healthy again, I would be very grateful. I was thinking of getting a smoke test but now thinking of testing the glow plugs next to see if they have failed as I thought it odd that three had come up with a fault at once.
Thanks in advance
Michael
Tuesday,06,September,2016,18:06:33:16492
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
www.Ross-Tech.com
VIN: TMBGS21Z462156959   License Plate:
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76
VIN: TMBGS21Z462156959   Mileage: 182340km-113300miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Malfunction 0010
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 K    HW: 028 101 223 7
   Component: R4 1,9L EDC G000SG  7002
   Revision: 12345678    Serial number: SKZ7Z0E3126418
   Coding: 0000071
   Shop #: WSC 73430 790 00000
   VCID: 2B5487028A455C1A2D-807E
4 Faults Found:
17055 - Cylinder 1 Glow Plug Circuit (Q10)
            P0671 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 966 /min
                    Torque: 26.8 Nm
                    Speed: 0.0 km/h
                    Load: 4.3 %
                    Voltage: 13.83 V
                    Bin. Bits: 00101000
                    Temperature: 84.6°C
                    Bin. Bits: 11111111
17056 - Cylinder 2 Glow Plug Circuit (Q11)
            P0672 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 966 /min
                    Torque: 26.8 Nm
                    Speed: 0.0 km/h
                    Load: 4.3 %
                    Voltage: 13.83 V
                    Bin. Bits: 00101000
                    Temperature: 84.6°C
                   Bin. Bits: 11111111
17058 - Cylinder 4 Glow Plug Circuit (Q13)
            P0674 - 000 - Electrical Fault
             Freeze Frame:
                    RPM: 966 /min
                    Torque: 26.8 Nm
                    Speed: 0.0 km/h
                    Load: 4.3 %
                    Voltage: 13.83 V
                    Bin. Bits: 00101000
                    Temperature: 84.6°C
                    Bin. Bits: 11111111
16485 - Mass Air Flow Sensor (G70)
            P0101 - 000 - Implausible Signal
             Freeze Frame:
                    RPM: 2058 /min
                    Torque: 0.0 Nm
                    Speed: 52.0 km/h
                    Temperature: 35.1°C
                    Absolute Pres.: 1193.4 mbar
                    (no units): 176.4
                    (no units): 0.67
                    Temperature: 81.9°C
Readiness: 1 1 0 0 0
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3F8CC3526E3DD0BA91-806A
No fault code found.
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1Z0 907 044 H
   Component: ClimatronicPQ35 084 0305
   Shop #: WSC 00000 000 00000
   VCID: 3B74B7427A25CC9ABD-806E
1 Fault Found:
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded - Intermittent
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000003534781
   Coding: 418A0F030004140000110D000000000000087F075C
   Subsystem 1 - Part No: 1Z2 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 73430
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: Q4 AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0KCPW+
   Coding: 0020788
   VCID: 377CAB72460DE8FA59-8062
   Subsystem 1 - Serial number: 6332MSME0B03024E5
   Subsystem 2 - Serial number: 6342MSME0C186942E
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   VCID: 76E26676018751F282-8022
1 Fault Found:
00888 - Wiper Switch for Intermittent Operation (E22)
            014 - Defective - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1Z0 920 910 D
   Component: KOMBIINSTRUMENT VD1 3562
   Coding: 0007401
   Shop #: WSC 80093 222 71269
   VCID: 34669C7E577B03E27C-8060
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 2800105809873C
   Coding: 3D3F0740072303
   VCID: 2A5A820685BF4512D6-807E
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO                3562
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN2.lbl
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2346
   Coding: 0000758
   VCID: 3662A676410711F242-8062
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 33649F62527504DA65-8066
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Component:    KSG              0401
   Coding: 01D002007F2D8505485F861004CC
   VCID: 79F86D4A30993E8AEF-802C
   Subsystem 5 - Part No: 1Z0 951 171
   Component: Innenraumueberw.008 4801
   Coding: 00000000
   Shop #: WSC 00000
   Subsystem 6 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 7 - Component:       NGS n.mounted
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN2.lbl
   Part No: 1T0 959 702 B
   Coding: 0000758
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1Z0 035 161 B    HW: 1Z0 035 161 B
   Component: Radio FO3       012 0028
   Revision: 00012000    Serial number: SKZ7Z3E0048038
   Coding: 0000402
   Shop #: WSC 28060 576 90107
   VCID: 2D50891AB451522A33-8078
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN2.lbl
  Part No: 1K0 959 703 E
   Component: Tuer-SG         021 2435
   Coding: 0000144
   VCID: 326A9A66AD6F0DD26E-8066
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN2.lbl
   Part No: 1K0 959 704 E
   Coding: 0000144
Address 76: Park Assist        Labels: 1Z0-919-283.lbl
   Part No SW: 1Z0 919 283 B    HW: 1Z0 919 283 B
   Component: Parkhilfe 4-Kan H04 0020
   Coding: 0000001
   VCID: 3D70B95A6431C2AA83-8068
End-------------------------(Elapsed Time: 01:36)--------------------------
Was it the timing belt that had snapped or the aux. belt? By the looks of the timing it looks like that has been replaced but surprised the engine hasn't been damaged.
May need them to re-do the timing belt or at least check it before doing any adjustments on the sproket
Is it a 1.9?
Edited by SuperbTWM
Thanks,
It was the Aux belt that snapped.
When I got the car it has a little leak from the fuel filter which I got repaired and new fuel filter and I was told it could have degraded the aux belt leading it to snap.  I have contacted someone to redo the timing belt asap and I will try to put a multimeter in the plugs tonight.
Yes it's a 1.9
Someone also told me that when an aux belt snaps it could dislodge the cam belt by a tooth or more if it gets caught up.  If this had happened to my car, would that give the -2.5 torsion value?  If so how much damage is that likely to have done to the engine? (I think I've travelled about 1000miles since the new turbo)
