Upgrading from Swing...
seems easier than the old double prong removal tool jobbies, its the VCDS programming thats the problem, that and adding the GPS, what about the DAB, thats a special aeriel too int it
None of those are difficult problems...
- VCDS programming is easy and I'm sure a local member would help.
- The GPS antenna is super easy. Most use a third party one either in the dash or attached to the front screen.
- The DAB antenna also isn't a problem, plenty of third party ones although not sure of quality.
Even if you did it properly and added the appropriate OEM antenna, it's not a hard job. You'll need to run two antenna cables up the A pillar to the rear of the car and replace the antenna. Can't be more than a couple of hours work.
Stop worrying, just make a decision and go with it ;)
can canista do the programming??
You mean Carista :)
Have no idea but don't think so - dongle alone - without subscription - is completely useless.
Edited by jafo
Son has decided to sell MY Superb Greenline SE plus "Ambition" without my knowledge and im yet to see the money
this will get messy
regarding Mk2 superbs (pre-FL and FL) are all the units interchangeable?
