How to get to Fabia horn?
Hi all,
Got a Fabia II HTP for my first car and I'm looking to change the horn. I've got the twin tone Bosch Ec9's, but I'm trying to figure out how to get to the actual horn. I don't have a fog light on the nearside, just a black plastic cover that looks like it has a little sensor in it. Could anyone tell me how to remove this? I've tried pulling but it feels clipped in place and I don't want to break it. Is there a little technicality to removing it or do I just need to use a bit more brute strength?
On the off chance someone else also has the Ec9 horns, what sort of other equipment do I need? All I've got is the 2 horns and a few nuts and bolts, no extra wires.
As Wonky says pull out the section of grill to the left of the blank and you 'should' be able to get the blanking plate out. The fog light assembly is held in with a clip on the unit itself so I see no reason that the blanking plate would not.
I was 'creative with the wiring and made my own loom. Not hard IIRC but can't completely remember, I think I used a selection of spade conectors and did it that way.
If you want to use a proper block I believe this is the correct one.... http://www.ebay.co.uk/itm/171210281239?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Cheers for your help guys, will test it out tomorrow and will definitely look into getting that connector jonro :)
