Tyre Pressure Monitor. What else.
Oooh. Can. Worms.
Nitrogen
Nuff said ?
Not intending to race cars or fly aircraft so continuing to use free air in my car tyres :-\
Nitrogen
Nuff said ?
Air is 79% Nitrogen.
Despite what is said the (tiny) benefit from using 100% Nitrogen isn't due to the gas content but due the removal of the water content in air.
  • 5 weeks later...
This seems as good a thread as any for this -
any links for these gadgets/guages?
Personally I find these (or similar) to be pretty good and I keep one in every car.
https://www.amazon.co.uk/RACE-RX0014-Tyre-Pressure-Gauge/dp/B000VZ8S26/ref=sr_1_1?ie=UTF8&qid=1478384774&sr=8-1&keywords=tyre+pressure+gauge
However if I want to get it right (or check the accuracy of one of the above) I use one of these  :)
https://www.amazon.co.uk/PCL-Inflator-General-Model-Hold/dp/B00OLY69BU/ref=pd_sim_sbs_60_4?_encoding=UTF8&psc=1&refRID=J00DE3Q1EP2NJNGNWSSR
I can recommend the RaceX dial gauge linked in the previous posting - and you can buy a lot of beer with the £46 you save over the high-tech PCL one.  I guess I must have an ancestor from north of the wall.
Warrior193
Nitrogen is a total waste of money, how do you purge any air from the tyre unless you put the whole wheel in a vacuum. Also if you top it up where would you fill it from?.
Edited by Alpha2110
Another good point. See my post #29.
