Sat Nav & POI
Hi,
I've spent the weekend reading every thread I could find on the subject but still no luck.   I have an Octavia VRS Nav.  Its a 65 plate, 2015 build (uk spec euro import).
I'm fairly sure my nav/entertainment unit is a columbus nav pro, but I'm not 100% sure and not sure how to be 100%.
Assuming I have the unit correctly identified, I've been trying to get POIs loaded on it (speed camera, certain fuel stations and a few other bits and bobs I'd like).   I've been through creating the zip file from the German site and putting it on an SD car.  But no matter what I do, what combination I try (have tried other columbus units), it always fails to recognise the update/data.
I've tried doing it via a system update, and from the memory management option -->  update my POI.
I know I could create a vCard for all points I want and import manually, but I would like to cover all of South Wales and the South West of England (my normal travel area), so doing a separate vCard doesn't seem a practical way to solve things.
Any help gratefully received as I'm at my wits end.
Matt
Bump.   Anyone have any advice or thoughts as I'm truly stuck with this!
On 22/01/2017 at 18:56, MattL said:
Hi,
Matt
Have a look at this thread, it may, or may not, help you.
https://www.briskoda.net/forums/topic/385044-poi/
