Black & White skoda emblem
Does anyone know where to get these from? On Instagram every vrs has them but I can't find them to buy.
  • Replies 74
  • Views 41.5k
Superskoda.com
Checked superskoda.com and couldn't see this, is there a part number/order number ?
Thanks.
They are not on superskoda. From what I can gather they are mostly home made. I think the badge comes apart and is sprayed. I have ordered 2 to try.
Like it, be nice to be rid of the chrome.
Please let us know how you get on. Be very interested to give it a go, black on meteor grey background.
Try looking for Monte Carlo parts as they are painted black for example Cat. number: O3-ZNK-BLK Superb III - original Skoda emblem in BLACK Monte Carlo edition - FRONT
Yep, seen them and they're nice, but v expensive. If I can mod the standard badges to black against a body coloured background as per the OP I'd rather do that.
Your right it does appear that they are in two parts, as seen on this video, when it comes apart as he's trying to take the badge off!
Badges have arrived, taken apart had to break the clips but will easily glue back together when painted. Will be a neater job this way instead of masking.
Looking good, where did you get them and what was the cost, what will you use for car body colour ?
Could the chrome bits just be painted black and stuck directly to the body, or are there holes behind the existing badges?
Got them from eBay official skoda ones. £30 for the pair
Nice little project.....something I've been planning to do.
Just out of interest what are the part numbers?
Any update OP?
Yes!. Very nice! So how did you do yours?
I've only done the front so far. This is what I did:
2 x Skoda badges from eBay, split them carefully  (remove the double sided backing, then the clips have to be broken to separate the parts.)
Cleaned all parts with panel wipe, painted chrome parts with black Plastidip. Sprayed the 'backing plate', using some plastic primer I happened to have. (Nearly colour matched the car :D)
Then sprayed the backing plate with a colour matched aerosol (Skoda steel grey F7A)
Glued the parts back together carefully. Sprayed the whole thing with several coats of clear lacquer supplied with the paint.
Lots of light coats is the way to go with all of the spraying.
Thick double sided tape applied to rear of badge and trimmed to fit around the edges, trying not to damage the Plastidip in the process.
Removed the old badges with a hair dryer, credit card and fishing line, and cleaned off the residue with tar remover.
The vRS badge was a pig of a job, it's glued to the grille so a bit of bravery was required to prise it off. Then masked it carefully, prepped with PW and sprayed away with Plastidip. Several coats plus lacquer, carefully removed masking tape and glued back on.
Not decided what to do on the rear, I have the Skoda emblem ready to swap but dunno whether to Plastidip the rest ot just remove them...
Just to answer my own question, yes, this could be done. I didn't want to remove my old badges to find out without having the new ones ready to go on, so ended up refitting the entire badges painted as above. There are three small recesses behind the central winged logo, these would be hidden once the painted parts are refitted.
The only issue would be that the parts would need to be glued to the paint, unless double sided tape could be applied very neatly to the rear.
I've now debadged the back of mine, and fitted the painted rear emblem to match the front. I'll get some pictures when it's clean :dry:
Where did you get the paint from guys?
Paint from ebay or amazon seems to cost more than the badges themselves...
Cheers
Cheers
Paint (and lacquer) from here.
These badges.
Plastidip from here.
About £50 all in for both badges and paints, so a good bit cheaper than two of the black OEM Monte Carlo ones from Superskoda, although it takes time and patience.
And you will have plenty of paint left over for further experiments ;)
and more importantly it's not a purchasable option. I'd have done that in a heart beat if it was
On 18/02/2017 at 18:39, pist0nbr0ke said:
Totally doing this next week. Remember seeing it somewhere before I got my car last year and then I put it on long finger, but after seeing this - looks amazing. Skoda missed a trick here, looks much more like it should on the VRS. So front and rear badges ordered, Vrs logo orderd, SKODA and OCTAVIA badges ordered for rear (not a fan of the de-badging - I want people to KNOW this awesome car is a Skoda :-) ) Touch up paint ordered.
Green and Red going on two front ribs of grill - also a trick missed by Skoda.
Booked in to have some side decals fitted in next week or two. Just something subtle along the bottom, skinny black with VRS in it.
Like this but in black: Just the side -
