US Blinkers menu adjustment
Hello guys,
I was wondering if anyone knows the modifications via VCDS or OBDEleven to activate US blinkers and modify the intensity through the infotainment menu. Please share :)
  • Replies 54
  • Views 36.4k
  • Awayoffski was suggesting that Audi drivers don't usually bother indicating changes in direction - probably because they are already in the back seat of the car in front.
  • Sorry, no help but GOOGLE,  'AUDI direction indicator delete / reactivation'.   (May require driver input by using the indicator stalk..)
  • ^^^ Sorry, my post was an attempt at humour and not a serious one.
PS: i have a VRS 2014 with MIB1
Adding US blinkers is already in the main tweaks section.
However it doesn't add the menu on the dash, you you need that really?
I saw that the activation of us blinkers is already in vcds adaptation. i activated them. i need that extra option to turn them on and off for the simple fact that in my country are not "very" legal :)
Following...
What I hate is US blinkers ON and rear red blinkers! Why they need to be special? And those res blinkers are F*cking confusing!
Edited by Croat
I find that I quickly get used to them when driving over there - but I think that "the rest of the world" solution for direction indicators is much clearer - and that is supposed to be the point, isn't it?
Yes! I mean red blinkers when hazards are turn on confused me I wasn't sure if some on was pressing and releasing brake like a noob driver in distance. And the it was a broken car on the side. WTF moment for me?
Red light is for position and break! Blinker is orange for a reason to be easier distinguished and so theres no confusion. Like why they have to be so special?
And that horrible orange light on front lights! Ahh!
Here is the configuration to put the US blinkers exactly like in the video above
Sorry for that being in german..but google translate could help you out.
This only works with handbrake disengaged and the doors closed.
If you want it to work independently of handbrake state leave the C0 and C1 with "Nicht active" option.
STG 09
Zugriffsberechtigung: 31347
Anpassung
Innenlicht Leuchtenkonfiguration
    Ambiente_Applikationsleiste_in_Instrumententafel
    auf "verbaut" setzen
Leuchte 0 BLK VL B36 (Blinker links)
    Lichtfunktion A 0
    Auf "Ambientelicht 1" setzen
    Dimmwert AB 0
    Auf gewünschten Dimmwert setzen
    Lichtfunktion C 0
    Auf "Handbremse ist angezogen" setzen
    Lichtfunktion D 0
    Auf "Innenlicht" setzen
    Dimmwert CD 0
    Auf "0" setzen
    Dimming Direction CD 0
    Auf "minimize" setzen
    Lichtfunktion E 0
    Auf "Blinken Links HELLPHASE" setzen
    Dimmwert EF 0
    Auf "100" setzen
    Dimming Direction EF 0
    Auf "maximize" setzen
    Lichtfunktion G 0
    Auf "Blinken Links DUNKELPHASE" setzen
    Dimmwert GH 0
    Auf "0" setzen
    Dimming Direction GH 0
Leuchte1BLK VRB20
    Lichtfunktion A 1
    Dimmwert AB 1
    Auf den selben Wert wie in Leuchte 0
    Lichtfunktion C 1
    Lichtfunktion D 1
    Dimmwert CD 1
    Auf "0" setzen
    Dimming Direction CD 1
    Lichtfunktion E 1
    Auf "Blinken Rechts HELLPHASE" setzen
    Dimmwert EF 1
    Auf"100" setzen
    Dimming Direction EF 1
    Lichtfunktion G 1
    Auf "Blinken Rechts DUNKELPHASE" setzen
    Dimmwert GH 1
    Auf "0" setzen
    Dimming Direction GH 1
STG 09
Anpassung
    Lichtfunktion A 0
    Dimmwert AB 0
    Lichtfunktion C 0
    Lichtfunktion D 0
    Dimmwert CD 0
    Auf "0" setzen
    Lichtfunktion E 0
    Dimmwert EF 0
    Auf "100" setzen
    Lichtfunktion G 0
    Dimmwert GH 0
    Auf "0" setzen
Leuchte1BLK VRB20
    Lichtfunktion A 1
    Dimmwert AB 1
    Lichtfunktion C 1
    Lichtfunktion D 1
    Dimmwert CD 1
    Auf "0" setzen
    Lichtfunktion E 1
    Dimmwert EF 1
    Auf"100" setzen
    Lichtfunktion G 1
    Dimmwert GH 1
    Auf "0" setzen
This for both then with the adjustment inside the cab?
Yes..for both of the front..and the adjustment is under light settings
Video here
Edited by SpikiE
Finally a straight answer! :) Thank you so much SpiKiE. You rock! :)
  • 3 months later...
Video here
I'm having problems doing this. I've tried twice now and resetting the headunits but nothing.
My vrs is a 2014 with the big head unit upgrade
  • 6 months later...
Hello guys,
I have the same problem with my vrs 15 also i checked it twice but the only thing i dont find is the first ambiente_applikastionleiste in instrument tafel on installed moved does any one know wich number it is of where i can find it.
Sorry for my bad english im from belgium  :)
STG 09
Anpassung
    Lichtfunktion A 0
    Dimmwert AB 0
    Lichtfunktion C 0
    Lichtfunktion D 0
    Dimmwert CD 0
    Auf "0" setzen
    Lichtfunktion E 0
    Dimmwert EF 0
    Auf "100" setzen
    Lichtfunktion G 0
    Dimmwert GH 0
    Auf "0" setzen
Leuchte1BLK VRB20
    Lichtfunktion A 1
    Dimmwert AB 1
    Lichtfunktion C 1
    Lichtfunktion D 1
    Dimmwert CD 1
    Auf "0" setzen
    Lichtfunktion E 1
    Dimmwert EF 1
    Auf"100" setzen
    Lichtfunktion G 1
    Dimmwert GH 1
    Auf "0" setzen
Is this working the same  with no led lights ?
Video here
How to add only adjustment under the lights settings . I have no led, just normal lights so all this costing is not working for me
Video here
How to add only adjustment under the lights settings . I have no led, just normal lights so all this costing is not working for me.
  • 4 months later...
Can anybody help with this doing in obd11 pro
I did it on my skoda from 2015 and it works fine for my only you must search good for the ambient lichte adjusment in the app:)
Can you screen shot the bit I need on the app and what I need to change please
