Electric windows lift up when lock the car with RC
Hi All,
VCDS related questions,
Is there a way with VCDS to set (activate if exists) that function when I locked the car with remote control the windows lifting up?
Is it possible to show Oil temperature display if no maxidot with VCDS?
Is there a complete list of comfort function which can activate / deactivate with VCDS? for example coming home, cornering function, rain sensor etc.
(for Superb II. 2.0 CR TDI DPF y2010, no maxidot)
Thank you in advance.
Edited by ujtordai
Yes you can close the windows by keeping the locked button pressed on the remote until they are fully closed (you can also open them by keeping the open button pressed) if this does not currently work then look for ‘comfort closing’ in VCDS.
Not sure about the oil temp as I have only ever coded MKII Superb with a maxidot, but I doubt it.
Take a look here for VCDS coding.
Hi
Thank you of your answer.
Is there a way to do this functionality without keeping the locked button pressed, just simply lock my car and it's automatically lift up the windows?
Thank you.
Not that anyone has found.
+1
