Service indicator
I have just serviced my variable service yeti.
I have reset the oil service indicator using the odo zero button.
But how do I reset the inspection service indicator.
Also I believe that by setting the oil service indicator myself I may have switched oil services to fixed, is that true.
If so how do I switch completely to fixed servicing and get rid of the annoying service indicator message.
I have reset the oil service indicator using the odo zero button. (1)
But how do I reset the inspection service indicator. (2)
Also I believe that by setting the oil service indicator myself I may have switched oil services to fixed, is that true. (3)
If so how do I switch completely to fixed servicing and get rid of the annoying service indicator message. (4)
1/ I've never heard of that method. Can you explain please?
2/ Although it can be done in the Maxidot menu I don't think that does it fully, and for that you need VCDS.
3/ Never heard of it. As above thought you needed VCDS to do that.
4/ VCDS again, and you will still get a message when the service is due.
to reset using odo , think you press odo and then turn on ignition!  -  tried it once but can't clearly remember sequence.
Then press minute button when message asks if you want to reset.
ta muchly!!  ; - ))
To reset the inspection light.. Turn on the hazard lights first then carry out the same sequence as to reset the service light
