VCDS Adaptations not taking
Been trying to get dual rear fog lights and cornering front fogs working. Have applied the settings as per the adaptations page. But they still refuse to work. Anyone had any luck on the FL?
Yes, I've managed to dual rear fogs. I did it via OBDeleven though. There is an extra step required. You need to define the lamp type for the NSR fog light. By default, no lamp type is defined so it won't work even if the other settings are correct.
Thanks will give that a go any ideas what the field is called? I followed the steps for the rest of it in the tweaks section
  • 4 weeks later...
Found what I thought was the type field for the Rear LED fog. Tried to set it to 32 or 37 in the adaptations 32 was set of the Drivers side rear, was something like 32 allegemeine LED bis 12W. But it didnt accept either setting for the Rear Passenger side fog light. Out of range was the error.
Any ideas.
