312mm brakes - Pictorial
Just to clarify, the 312mm setup from a Mk1 Octy vRS will fit the Mk2 Fabia vRS, correct? Was originally just going to get up-rated pads+discs but opinions seem to be that the gain from the larger brakes is worth the extra $$$ spent.
  • Replies 132
  • Views 89k
  • Makes sense
  • I'll be sure to post pics of those same Zimmermans fitted to mine later this week, just to tempt you even further
  • You will be fine then. It's a cautionary warning that's all, doesn't happen all the time but can. If it had gone wrong you would know about it.
Yes it will.
  • 5 months later...
I have bought 312mm and 256mm upgrade for my Fabia VRS mk2 2010, got them off the old S3 2000 model. The fronts fit fine but the rears i cant get on. The carrier doesnt go round the disc it catches and it doesnt bolt to the hub there a gap? anyone had this before??
Any chance the OP could sort the pics out please? :blush:
Update to fix the broken pics would be ace ...
Who would you like to pay for them to be available again?
I'd happily rebuild the original if the images where emailed to me so I could host them again ;)
  • 3 years later...
Images should all be working now.
  • ColinD unpinned this topic
