2014 vrs overheated
2.0 TSI is chain driven. Think some of the smaller petrols are belt.
The 1.0, 1.2 and 1.4 FSI are all belt.
My 2014 VRS TDI came up for a major service so decided to have the water pump changed last week (after seeing all the forum posts in here about overheating) All in all I had the following done:
New Water pump + Cambelt
DSG oil & Filter change
Full Major service
New front Pads
Diagnostic
Courtesy Car for 2 x days
 Came in at roughly £1250,  this was by a local specialist dealer who i cant recommend enough, brilliant service. Car had only done 38,456 miles but I decided to have it done for peace of mind, and since I share the car with my other half I prefer to keep it in best mechanical condition I can, although ive never had an issue with this car overheating, I know a friend who had no end of problems with his golf GTD, and since the cars are quite similar engine wise I thought it best to be done.
Edited by VRSrobster
This issue came up with my 14- Mklll 1.6 Dti Elegance 44.4k
1: Sensor replaced ...No change.
2: Electronic Water Pump replaced...No Change
3: Mechanical Water Pump/Seal + Cam Belt Job done
It appears there are actually 3(three) water pumps on these, who knew?
when talking to Skoda UK they say they have no knowledge..
tried to get my local main dealer to do it but their lead time was over three weeks...( they would it Looker at it )
Therfore Skoda UK won't talk about it... good customer relations
Edited by MisterBo
Grammar
Different matter,
but Euro 6 1.4TDI 3 cylinder engines are having water pump failures and the reason given by the VW Group is 'wrong coolant',
so they get the Coolant changed,  Water pumps replaced, and maybe even water pumps replaced again.
Odd that those with the changed coolant can have the replacement water pumps fail.
Pinned thread at top of Fabia Mk3 section if anyone is interested.
http://briskoda.net/forums/topic/426322-recall-on-diesel-cooling-issue
'Recall' usually mean Recalling and not just Skoda Service Campaigns, or Skoda Secret Service Campaigns.
http://master.skoda-auto.com/mini-apps/recall-actions
Edited by Headinawayoffski
It should be pointed out that generally the pump itself doesn't fail, but the issue is that the sleeve which moves out to reduce water flow (to aid a faster warm up for the 'larger' diesel block) gets stuck instead of returning to its natural position once the water is up to temperature.
Specially this happens on VRS CR made around 2014, the part was later revised to prevent the sleeve from getting stuck.
  • 5 months later...
I'm due to buy a 2014 vrs from Yorkshire this week, does anybody have the part number for the updated water pump? I'm wondering if it's possible to visibly check if the car I'm buying has had the upgraded pump fitted.
I don't think it's possible to see the part number, but most seem to be getting replaced with 04L121011L.
Receipts would be the best proof that it's been done.
or if it was done at a Skoda garage, you can ask the seller for a printout of the worksheet/service log direct from Skoda
