VRS high idle
Hello everyone I've a question.
Sometimes my car is idling at around 1000-1100 rpm. Is this normal? If not, what would cause the car to idle so high?
It’s to do with the ambient temperature, and if I remember correctly, fuel temperature.
This is can be edited in your mapping :) you can choose what speed you’d like it to idle
In my case, "odd" idling was either CTS or FTS going tits up. Fuel/Coolant temp sensors. Though there was also a problem with late models and the accelerator pedal.
Uhh what is CTS and FTS?
Fuel temp sens. Coolant temp sensor
Do the revs drop back down if you tap the underneath of your throttle with your toe ?
