Rear camera owners - views?
 My local dealer installed the camera and the necessary cabling, when they tried to code it using their equipment they couldn't.
 They then got in touch with Skoda UKs technical department who pointed them to a small paragraph in a technical document which stated that the reversing camera could not be retro-fitted to Superbs built after week 22 (2017).
  I myself do not understand what the difference between a factory fit and a retro-fit is provided all the necessary wiring/connectors are installed.
We were quoted £430 for supply and fitting of the camera.
 I'd be delighted if somebody could explain to me how to code a camera in using VCDS as I've told Thomson & Potter that if I find a work around to the alleged issue I'll get them to refit the camera and I'll code it in myself.
If its any help, here is a scan of my car which has had the camera retrofitted, although it is an earlier car than yours (early 2016) . You can see that there is a fault code in the camera module - no basic setting. But despite that, it works fine. Also showing the fault for the AWD - now fixed with new pump.
Wednesday,08,November,2017,15:11:53:18227
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 17.8.0.1 (x64)
Data version: 20170721 DS276.2
www.Ross-Tech.com
VIN:   License Plate:
Chassis Type: NP-SK48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 47
          52 55 57 5F 69 6C 6D A5 BB BC
VIN:   Mileage: 32491km-20188miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
13-Auto Dist. Reg -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
22-AWD -- Status: Malfunction 0010
2B-Steer. Col. Lock -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
57-TV Tuner -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
69-Trailer -- Status: OK 0000
6C-Back-up Cam. -- Status: Malfunction 0010
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
BB-Door Rear Drv -- Status: OK 0000
BC-Door Rear Pass -- Status: OK 0000
Address 01: Engine (J623-CJXA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259 B    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0002
   Revision: --H13---
   Coding: 0A1D00322476010B3004
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_ECM20TFS0203G0906259B 001003
   ROD: EV_ECM20TFS0203G0906259B.rod
   VCID: 2B5105BD4242031E0F-807E
No fault code found.
Readiness: 0000 0001
Address 02: Auto Trans (J743)       Labels: 0D9-927-770.clb
   Part No SW: 0D9 300 012     HW: 02E 927 770 AQ
   Component: DQ250-6A MQB  H53 4908
   Revision: 06253104    Serial number: TFK01512171245
   Coding: 0014
   ASAM Dataset: EV_TCMDQ250021 001001
   ROD: EV_TCMDQ250021_VW37.rod
   VCID: 53A17D5D3AB27BDE67-8006
1 Fault Found:
10763 - Starter Enable from Selector Lever Sensor System
          P1734 00 [002] - -
          Intermittent - Not Confirmed - Tested Since Memory Clear
Address 03: ABS Brakes (J104)       Labels:. 5Q0-907-379-IPB-V1.clb
   Part No SW: 3Q0 907 379 AB    HW: 3Q0 907 379 G
   Component: ESC           H42 0723
   Revision: 00000000    Serial number: 60116000000737
   Coding: 1E07939C54252B71077C070341C66978C92AD4E0E08296F5384150F8C2A9
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034036
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 7AFFF0F9FD986A96C4-802E
Address 05: Acc/Start Auth. (J518)       Labels:| 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 C    HW: 3Q0 959 435 C
   Component: VWKESSYMQB    036 0710
   Revision: 00036000    Serial number: 0391832920
   Coding: 030C0C0703
   ASAM Dataset: EV_KessyHellaMQBAB 004032
   ROD: EV_KessyHellaMQBAB_004_VW37.rod
   VCID: 3A7F30F9BD18AA9684-806E
   Sensor Controlled Power Rear Lid:
   Subsystem 1 - Part No SW: 3AA 962 243 E    HW: 3AA 962 243 E
   Component: GEB.F.Heckoef  H16 0813
   Serial number: 65047523
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 3V0 907 044 AJ    HW: 3V0 907 044 AJ
   Component: AC Automat    H32 3701
   Revision: 20K05000    Serial number: 00000B00056520
   Coding: 12110004000400011005104100101102
   ASAM Dataset: EV_ACClimaPrehVW37X 002012
   ROD: EV_ACClimaPrehVW37X_002_VW37.rod
   VCID: 7CF3F6E1F7AC54A6D6-8028
   Rear Climatronic Operating And Display Unit:
   Subsystem 1 - Part No SW: 3V0 907 049 C    HW: 3V0 907 049 C
   Component: E265KlimaHeck  H02 0101
   Serial number: 00000000000000000000
   Coding: 000000
Address 09: Cent. Elect. (J519)       Labels:| 5Q0-937-08X-HV1.clb
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Component: BCM MQBAB H   H24 0175
   Serial number: 01061601501333
   Coding: 0F031B66C2C72AFB17844086B11C572C0800000000000000000000000000
   ASAM Dataset: EV_BCMMQB 015001
   ROD: EV_BCMBOSCH_015_VW37.rod
   VCID: 091D9F35A87E710EDD-805C
   Control Unit For Wiper Motor:
   Subsystem 1 - Part No SW: 3V2 955 119     HW: 3V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: 48x RL 150320  032 0121
   Serial number: 00000001503180600354
   Coding: 165DDD
   Rain Light Recognition Sensor:
   Subsystem 2 - Part No SW: 5Q0 955 547 A    HW: 5Q0 955 547 A  Labels: 5Q0-955-547.CLB
   Component: RLHS  037 0059
   Serial number: S3Y16M01D20H17M08S35
   Coding: 0088DF
   Sensor For Anti Theft Alarm System:
   Subsystem 3 - Part No SW: 5Q0 951 172     HW: 5Q0 951 172
   Component: Sensor, DWA  005 0316
   Serial number: 000000000ZY1532727R6
   Alarm horn:
   Subsystem 4 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000064618552
Address 10: Park/Steer Assist (J791)       Labels:| 5Q0-919-298.clb
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183615317
   Coding: 0371167951
   Shop #: WSC 51091 002 1048576
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000_009_VW37.rod
   VCID: 0D15AB25DC166D2EF1-8058
Address 13: Auto Dist. Reg (J428)       Labels:| 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0192
   Coding: 320067CB55FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001008
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34631EC19F7C5CE65E-8060
Address 14: Susp. Elect. (J250)       Labels: 5Q0-907-376.clb
   Part No SW: 5Q0 907 376 A    HW: 5Q0 907 376 A
   Component: DAEMPFUNGS-SG H17 0120
   Serial number: 29121541350554
   ASAM Dataset: EV_DRCONTITEMIC 001019
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 377929CD8E0AB7FE7B-8062
Address 15: Airbags (J234)       Labels:| 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 AK    HW: 5Q0 959 655 AK
   Component: AirbagVW21    005 0130
   Serial number: 003Q5R1CPP1$
   Coding: 98CCC0C0000000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   ROD: EV_AirbaVW20SMEVW37X_SK48.rod
   Side Sensor Driver Front:
   Subsystem 1 - Part No SW: -----------    HW: 480 001 201 16
   Component: SideSensor_Df  001 0887
   Serial number: 357000000003D0FC081O
   Coding: 2D2D2D
   Side Sensor Passenger Front:
   Subsystem 2 - Part No SW: -----------    HW: 480 001 101 16
   Component: SideSensor_Pf  001 0887
   Serial number: 35800000000D9759581U
   Coding: 2D2D2D
   Side Sensor Driver Rear:
   Subsystem 3 - Part No SW: -----------    HW: 480 401 301 16
   Component: SideSensor_Dr  001 6149
   Serial number: 3510002AF1E85EA360EP
   Coding: 2D2D2D
   Side Sensor Passenger Rear:
   Subsystem 4 - Part No SW: -----------    HW: 480 401 301 16
   Component: SideSensor_Pr  001 6149
   Serial number: 35200029B1E9F1044071
   Coding: 2D2D2D
   Front Sensor Driver:
   Subsystem 5 - Part No SW: -----------    HW: 480 401 301 16
   Component: FrontSensor_D  001 6149
   Serial number: 35500029F1E85EA2C23O
   Coding: 2D2D2D
Address 16: Steering wheel (J524)       Labels:| 5Q0-953-549.clb
   Part No SW: 3Q0 953 521 BD    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160118401316
   Coding: 6410
   ASAM Dataset: EV_SMLSVALEOMQB 001015
   ROD: EV_SMLSVALEOMQB_VW37.rod
   VCID: 73E1DDDDDAF21BDE87-8026
Address 17: Instruments (J285)       Labels:| 5G0-920-XXX-17.clb
   Part No SW: 3V0 920 910     HW: 3V0 920 910
   Component: KOMBI         306 6422
   Coding: 27A5081AFF84A600018B6A0B5001000000000000
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_DashBoardVDDMQBAB 009046
   ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
   VCID: 6ED7CCA9B1D0363668-803A
1 Fault Found:
1048578 - No Basic Setting
          B2010 00 [009] -  -
             Freeze Frame:
                    Fault Status: 00000001
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 72
                    Mileage: 32473 km
                    Date: 2017.11.07
                    Time: 10:02:13
Address 19: CAN Gateway (J533)       Labels:| 5Q0-907-530-V1.clb
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 20011610802757
   Coding: 030100347F085900EB00025A9C0F00010001070000000000000000000000
   Shop #: WSC 131071 1023 2097151
   ASAM Dataset: EV_GatewConti 013020
   ROD: EV_GatewConti_013_VW37.rod
   VCID: 79FDEFF5F89E618ECD-802C
   Alternator:
   Multi Function Steering Wheel Control Module:
   Subsystem 2 - Part No SW: 3V0 919 719 B    HW: 3V0 919 719 B
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000B1148130116
   Battery Monitoring Control Module:
   Subsystem 3 - Part No SW: 5Q0 915 181 G    HW: 5Q0 915 181 G
   Component: J367-BDMHella  H04 8050
   Serial number: 6483728903
Address 22: AWD (J492)       Labels:* 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 H    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7083
   Serial number: HA1-00001.12.15
   Coding: 0301
   ASAM Dataset: EV_AllWheelContrHA1VW37X 004013
   ROD: EV_AllWheelContrHA1VW37X_004_VW48.rod
   VCID: 4A9F6039EDF83A1614-801E
1 Fault Found:
16671 - Pump for Haldex Clutch
          C1112 04 [008] - Internal System Fault
          Intermittent - Confirmed - Tested Since Memory Clear
             Freeze Frame:
                    Fault Priority: 1
                    Fault Frequency: 1
                    Reset counter: 113
                    Mileage: 32491 km
                    Date: 2017.11.08
                    Time: 15:04:14
Address 2B: Steer. Col. Lock (J764)       Labels:| 5Q0-905-861.clb
   Part No SW: 3Q0 905 861     HW: 3Q0 905 861
   Component: ELV-MQBB      H05 0032
   Serial number: 15000166084013
   Coding: 0800000000000000
   ASAM Dataset: EV_ELVMarquMQBB 001007
   ROD: EV_ELVMarquMQBB_VW37.rod
   VCID: 71EDD7D5A0EE29CE75-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006OLM12228
   Coding: 001400000000010001A080808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_001.rod
   VCID: 3B7135FDB222939E9F-806E
Address 3C: Lane Change (J1086)       Labels:* None
   Part No SW: 5Q0 907 686 B    HW: 5Q0 907 686 B
   Component: HRE_Master    H11 0071
   Serial number: 0391043522
   Coding: 02012203
   ASAM Dataset: EV_HREntryHella 001028
   ROD: EV_HREntryHella_VW32.rod
   VCID: 3C7336E1B72C94A696-8068
   Lane Change Assistant 2:
Address 42: Door Elect, Driver (J386)       Labels:| 5QX-959-X93-42.clb
   Part No SW: 5Q0 959 593 E    HW: 5Q0 959 593 B
   Component: TSG FS        020 0041
   Serial number: 031115BK211079
   Coding: 001D0820DE01040000001100
   ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003
   ROD: EV_DCUDriveSideEWMAXCONT_VW37.rod
   VCID: 43814D1DCAD2EB5ED7-8016
Address 44: Steering Assist (J500)       Labels:| 5Q0-909-144.clb
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 9303
   ASAM Dataset: EV_SteerAssisMQB 012140
   ROD: EV_SteerAssisMQB.rod
   VCID: 44834E01CFDCEC66EE-8010
Address 47: Sound System (J525)       Labels:* None
   Part No SW: 3Q0 035 466 A    HW: 3Q0 035 466 A
   Component: MIB2_amp_P_SK H02 0250
   Revision: 00000001    Serial number: SKZ8Z1FAS013YQT
   Coding: 0384020000AA002FAA0000000000
   ASAM Dataset: EV_AMPMst16C5Gen2ALPI 001001
   ROD: EV_AMPMst16C5Gen2ALPI.rod
   VCID: 2D550BA57C560D2E11-8078
Address 52: Door Elect, Pass. (J387)       Labels:| 5QX-959-X92-52.clb
   Part No SW: 5Q0 959 592 E    HW: 5Q0 959 592 B
   Component: TSG BFS       020 0041
   Serial number: 061115BK507897
   Coding: 001D0220DE01040000001100
   ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003
   ROD: EV_DCUPasseSideEWMAXCONT_VW37.rod
   VCID: 428F4819D5C8E256DC-8016
Address 55: Headlight Range (J745)       Labels:| 7P6-907-357.clb
   Part No SW: 7P6 907 357 D    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0090
   Revision: --------    Serial number: --------------
   Coding: 06E602003F010000
   ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120
   ROD: EV_HeadlRegulVWAFSMQB.rod
   VCID: 408B4211DBC4F046CA-8014
   Left Headlamp Power Output Stage:
   Subsystem 1 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0006
   Coding: B20000
   Right Headlamp Power Output Stage:
   Subsystem 2 - Part No SW: 8U0 941 329     HW: 8U0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0006
   Coding: B20000
Address 57: TV Tuner (R78)       Labels:* None
   Part No SW: 8V0 919 191 C    HW: 8V0 919 191 B
   Component: DVB-DTV       H09 1800
   Coding: 0304030000000100000000
   ASAM Dataset: EV_TVMELC 001033
   ROD: EV_TVMELC_VW37.rod
   VCID: 3F8941EDA63A8FBEB3-806A
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-HGH2.clb
   Part No SW: 3V0 035 020 B    HW: 3V0 035 020
   Component: MU-H-ND-EU    H50 0318
   Serial number: A676A0GB009068
   Coding: 038402010000000011111202008808002F0003E6012081009E
   Shop #: WSC 131071 102 209715
   ASAM Dataset: EV_MUHig4CGen2HBAS 001001
   ROD: EV_MUHig4CGen2HBAS_SK37.rod
   VCID: 2545F38524A6356ED9-8070
   Operating And Display Unit 1:
   Subsystem 1 - Part No SW: 3V0 919 606     HW: 3V0 919 606
   Component: ABT_High-2  H46 1031
   Serial number: SKZ8Z9SFP003YG
   Data medium:
   Subsystem 2 - Part No SW: V03 959 801 JN    HW: -----------
   Component: ECE 2017/2018  --- 0161
   Serial number: --------------------
   Compact Disc Database:
   Subsystem 3 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote2  --- 1012
Address 69: Trailer (J345)       Labels:| 5Q0-907-383.clb
   Part No SW: 5Q0 907 383 H    HW: 5Q0 907 383 C
   Component: Anhaenger     H21 0203
   Revision: 8B001003    Serial number: 0391775219
   Coding: 0100000202000000
   ASAM Dataset: EV_TrailFunctGener2Hella 001008
   ROD: EV_TrailFunctGener2Hella_VW26.rod
Address 6C: Back-up Cam. (J772)       Labels:| 5Q0-980-556.clb
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 04840201A700201F000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
   VCID: 77F9E9CDCE8A77FEBB-8022
1 Fault Found:
10489856 - No Basic Setting
          B2010 00 [009] -  -
             Freeze Frame:
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 72
                    Mileage: 32473 km
                    Date: 2017.11.07
                    Time: 10:02:13
                    passive
Address 6D: Trunk Elect. (J605)       Labels:| 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30450676100000
   Coding: 0D88
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   ROD: EV_DeckLidCONTIAU736_VW37.rod
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 D    HW: 3Q0 980 654
   Component: MQB_B_MFK     H04 0024
   Serial number: 05011611K21106
   Coding: 020408020000040100062347C040A00098000E100020
   ASAM Dataset: EV_MFKBoschMQBB 001001
   ROD: EV_MFKBoschMQBB_VW36.rod
   VCID: 387B2AF18314B88672-806C
Address BB: Door Rear Drv (J388)       Labels:* None
   Part No SW: 5Q0 959 395 E    HW: 5Q0 959 395 B
   Component: TSG HFS       020 0041
   Serial number: 011215BKU09388
   Coding: 001C00208001040000001100
   ASAM Dataset: EV_DCURearDriveMINKLO 006003
   ROD: EV_DCURearDriveMAXCONT_VW37.rod
Address BC: Door Rear Pass (J389)       Labels:* None
   Component: TSG HBFS      020 0041
   Serial number: 011215BKU0373B
   ASAM Dataset: EV_DCURearPasseMINKLO 006003
   ROD: EV_DCURearPasseMAXCONT_VW37.rod
End-------------------------(Elapsed Time: 06:17)--------------------------
Thanks for the scan, that's much appreciated.  :thumbup:
 I think what I probably need is a scan of an MY18 car that's fitted with a reversing camera so I can compare it with a scan of my car.
Edited by Derek_Mac
  • 1 year later...
Did anyone manage to get a rear camera retro fitted to a MY18 model?
You can source the kit from Kufatec, with coding talk to Alex at www.vagcarcoding.com as I'm pretty sure he could remote code it for you.
Edited by ZacDaMan72
As the instigator of this thread and now having had the car for 18 months, if you are thinking about getting a camera, DO IT!  Its just fabulous and makes reversing up to a trailer hitch a doddle, as well as being really useful for general manoeuvring.
We've got a new Karoq comming next week for t'missus, and if it hadn't had the camera as standard it would have been first thing on the options list.
The trouble is, when I get into other-half's car and reverse, I keep looking stupidly at the dashboard expecting to see the reversing camera image - which isn't there!
Its not the *entire* reason we are changing t'missus's Yeti for the Karoq, but it is quite big part of it 🙂 I think we've essentially been so spoiled by the Superb, we've built the Karoq into a 'mini-me' spec wise - it comes with the camera and we've added ACC, heated screen, heated rear seats, poncy towbar, traffic sign recognition and gone  for DSG, all 'cause we like them in the Superb!
