Scary Sudden Steering Jerks
I've had a Clio do something similar when the inner cv gave up, but you're very confident that the shafts are good... can't help bro.
9 hours ago, faker said:
...but you're very confident that the shafts are good...
No, I'm not. I'm taking into consideration replacing CV shafts too as a backup solution. Time will tell.
@RicardoM - IME rain can act as a lubricant for corroded metal joints and squeaky rubbers. I'm not saying this explains why your symptoms manifested in the wet but it might be the reason.
I thought of that too.
Time will tell sir. Good luck
faker
Please tell me more details about the Clio event.
Did you eventually see hard proof of faulty CV? Or you concluded it had to be the CV only because you replaced it on a hunch?
5 hours ago, RicardoM said:
faker
Hi Ricardo. Inner CV joint failed, which caused the steering wheel to jerk as you have described. I checked the inner CV and found that it had excessive movement and play due to wear (able to move shaft up and down in the inner CV housing). New shaft rectified the problem. Should also mention that for a period of time prior to the CV failing, there was a slight vibration under acceleration, which was also rectified when the shaft was replaced. The worn inner CV was throwing the balance off.
This is an information worth keeping in mind.
In conclusion, both excessive play and partially seized CV joints (mentioned earlier by Rustynuts) can result in sudden, random steering jerks on the same side with faulty CV.
