FUEL LEAK Fabia 1.6 TDI
Hi Guys,
I needed some help, i changed the injector on my Fabia 1.6 TDI 2010 and ever since the fuel return conduit that goes into the Injector keeps coming off and leaking diesel everywhere.
Do i need to change the whole pipe or can i super glue the dame thing to the Injector?
Ta
  • 6 months later...
On 02/12/2017 at 12:16, BigTahir said:
Hi Guys,
Ta
Hi, was your issue resolved if so ehat method did you use to fix the issue. Im having the same issue i think.
No ****er on here helped or commented. But in the end after trying a few methods it was just easier to buy a new return pipe and change the u clips.
Hope that helps. Ended up costing a extra 150 as I choice to buy a new one.
@BigTahir - Because no-one actually knew the answer! Well beyond that superglueing a pipe in place is storing up issues for the next time you need to remove it.
