Wonky Headlights!
Ill set the scene......
Driving along at night so headlights on (auto with adaptive cornering etc...), I notice the headlights turning with the direction of the steering as it should but the right hand headlight appears to get 'stuck' pointing out to the right and towards the oncoming traffic. Once I slow sufficiently (or park), you can visibly see the beam re-centralising.
Any idea how I can reset things or is this a trip to the dealers?
The lights auto level and centre each time you start the car.
If your dipped beam is sticking and wrongly shining at other road users rather than to your verge side please have that fixed ASAP.
Doesn't sound right. Basic settings in VCDS may help if you have access to that, assuming there isn't something physically interrupting the motion.
If it's causing an issue, potentially blinding other road users, may I suggest using Individual profile and setting the headlight movement to "Eco", or alternatively use the dipped headlight position on the headlight switch rather than Auto. Either of these effectively disables the turning function of AFS and leaves the lights pointing forwards regardless of steering angle.
Edited by ahenners
That is how they set the AFS to work, the O/S headlight at lower speeds should be pointing more to the O/S to light up the pavement on the opposite side of the road so you can see pedestrians apparently. It should only do that at lower speeds though, not all the time. If it is doing it all the time then something has gone adrift with the AFS.
If that is 'apparently' true someone needs a hard slap.
The UK Highway code and law on dazzling other road users is clear enough.
Road Users not all being car or motorised vehicle drivers in 20, 30, even 50 mile per hour urban areas.
thanks for the replies. I do not have access to VCDS I'm afraid......
it does it on main beam as well as dipped though and it does it at any speeds, I've noticed it over 60mph anyway.
From the handbook:
The AHL system operates in the following modes.
Out of town mode
The cone of light in front of the vehicle is similar to the low beam. The mode is
active if none of the following modes are active.
City mode
The cone of light in front of the vehicle is adjusted so that it illuminates the adjacent
pavement, crossings, etc. The mode is active at speeds of 15-50 km/h.
Motorway mode
The cone of light in front of the vehicle is adjusted so that the driver can respond
in time to an obstruction or other hazard in time. The mode is active at speeds
above 110 km/h.
Rain mode
The cone of light in front of the vehicle is adjusted so that the driver can reduce
the glare from oncoming vehicles in rain.
The mode is active at speeds of 50 – 90 km/h and if the windscreen wipers continuously
operate for a period of time longer than 2 minutes. The mode is deactivated
when the windscreen wipers are switched off for longer than 8 minutes.
Fog mode
The cone of light in front of the vehicle is adjusted so that the driver is not dazzled
by the reflection of the cone of light by fog in front of the vehicle.
The mode is active at speeds of 15 – 70 km/h and if the rear fog light is switched
on for a period of time longer than 10 seconds. The mode is deactivated when the
rear fig light is switched off for longer than 5 seconds.
Dynamic cornering lights
The cone of light in front of the vehicle is adjusted to the steering angle so that
the road in the curve is illuminated. This function is active at speeds greater than
10 km.h and in all AFS modes.
Tourist light
This mode makes it possible to drive in countries with opposing traffic system
(driving on the left/right) without dazzling the oncoming vehicles.
When the “tourist light” mode is active, the above-mentioned modes and the side
swivel of the headlights is deactivated.
The "Tourist light" mode can be configured in the Infotainment » operating instructions
for Infotainment, chapter Setting vehicle systems (CAR button).
Edited by mk4gtiturbo
Scary thing is how many vehicles are imported to the UK from a factory, given a UK Dealership Joke PDI and are then on the road for 3 years before a MOT
and the UK failure rate is high at first MOT's on Head Light adjustment.
All the gear fitted and doing it's own thing and you hope it all works,
and you only know it is maybe not as other dazzle you to say 'Sort your fancy lights out'.
Edited by AwaoffSki
this sounds perfectly normal for the light behaviour - as posted before, the lights are in city mode and won't "straighten up" until you're doing over about 35/40 mph, or as you say you stop the car.
Before you get too carried away it might be worth double checking that the lights are set for driving on the left.
Thats just how I experience "rain mode". Its really useless. Cant see see s*** on dark roads in the rain unless turn off the auto lights.
It's been asked many times, and it can be fixed with VCDS by disabling city mode.
Find a local member here on the map who can do it for you.
Ive done quite a few
