Coilovers or spring
  • Sponsor
On 17/02/2018 at 11:27, Bsissons said:
Just had a quote through for fitting and alignment £327 inc vat. Eibach Coilovers I've  seen at £875.00.
Is this about right?????
Including alignment it's probably not far off, maybe a little high but not crazy I'm guessing the alignment is around £60+ alone?
Don't hesitate to give us a shout once you have found the best price for the coilovers and we'll see if we can beat it for you.
Damian @ DPM Performance
The fitting quote was all included so not sure what the alignment cost was. I would trust this garage as they are always busy. I have sent you a message about the prices ive found.
Anyone know what would be causing my standard suspension to squeek. Front passenger side?????
Been doing it the last 2 or 3 weeks.
Every rapid I’ve owned and driven has squeaked... I thoughts suspension but I think others on here found it was the gear box?
OK the reason I thought it was the front left suspension is because everytime that front side goes over a bump it makes the noise. Is there anything to look out for regarding the gear box???
Lots of Rapid / Toledo squeaks front left - it's a suspension issue - something to do with a drop link?
One of the owners on here or SCN had the whole front left corner replaced bit by bit under warranty and it still squeaked.
Edited by camelspyyder
