Electric window fault
Hi all,
The electric window switch in my car seems faulty. It will control the passenger window fine and lowered the drivers window but now it is stuck down and won’t rise up again which is annoying. I wondered if this likely to be the switch or the wire that controls the motor raising. When you push the switch down you hear the motor engage but it stops as it’s already down. When you pull it up it doesn’t do anything at all.
Have you tried to close the windows with the remote key?
No I’ll give that a go. Just hold the lock button down?
Genius. That worked. At least motor is ok. Must be switch or wire. Thanks
:) no problem at least that's sort of good news. Good luck
