Initial impressions - disappointed
xman, sorry if it is already posted but what tyre pressures did you set first and have you tried any adjustment up or down since?
  • Replies 64
  • Views 7.8k
  • Yawn ...
  • Ok ok, I'll check the tyres.   I am just going outside and may be some time.....
  • Why do people give up so young. Our neighbour at the last house told me as he turned 65 that he could not see himself driving much longer and the car would have to last him.   Me and the Mrs
I'm worried that over 20 years xmans superb + fuel + servicing + tyres + road tax + break downs + insurance etc  will cost more than 80,000 miles in taxis.  He doesn't seem overly keen on car ownership.
Worry not.
I don't do break downs.
Or taxis.
Breakdows and Courtesy cars more commonly part of New Skoda ownership these days.
What pressures were in the tyres at hand over?
& what are the tyre pressures at now?
Have you checked the wheel bolt torque yet?
Not checked them, that was the dealers job at pdi. Yes I know they might be wrong, but unlikely as the tyres have probably not been touched since build. Will get round to it eventually.
You are serious arn't you,  and yet you started this thread on the new car,  & post all the time about what Main Dealer Servicing is like,
Wheels never off etc.
Slighty surprised at some of the very strong views being expressed. I was just giving a little feedback - chill - I don't want to criticise anyone, I am often guilty of enthusing about things when maybe really I am subconsciously only justifying my decision. :notme:
I suppose the intended message to others was, think very carefully about what is important to you and go for several meaningful test drives, more than once and over different cars. I dismissed other cars (Mercs, BMW, Audi, VW even Ford) because of old preconceptions of those marques and some idleness on my part. I'm stuck in a rut with Skoda because I have bought nothing but for the last 14 years, and "better the devil you know" attitude.
At least repair costs should be reasonable (compared to some other equivalents)
In the end I let my heart rule my head, and bought (and specced up too high) on impulse, maybe my biggest regret. Should have gone basic.
As I said before, give me some time to get used to it, and I'll try to be more objective. Maybe I'll grow to love it.....subconsciously ;)
If the Tyres are at 50PSI that will not be a surprise,
the person on £7.50 an hour or less if under 25 years old just does what they are taught to sometimes, or what they can get off with doing or not.
I've had two Superbs over the last 8 years. Both came with woefully incorrect tyre pressures from new, and they were even different at every corner! Many Skoda dealerships can barely remember to remove the transport blocks from the suspension, let alone set the pressures correctly. :D  Get them checked when cold xman.
I'm running P7s on 19" and I'll be looking for something different when they expire. Road noise hasn't been a problem (most of it is from potholes anyway round here) but wet grip isn't great. Way too much understeer doing sharp left/right turns at relatively slow speed.
Slightly OT but when my wife's Fabia went in for a service they set the tyres to 22 PSI instead of 2.2 bar. Some muppet must have flipped the fuel cap to check the correct pressures, mis-read it and never though to themselves "22, seems a bit low. Better double-check that".
Tyres are over inflated at the factory when the tyres are fitted and are left high for transportation. Setting them at the correct pressure is part of the PDI.
If they have not been touched since the build they will be high.
34psi all round
2 hours ago, xman said:
34psi all round
That's not too bad then. Try 38 psi all round, the eco setting. They'll be harder, naturally, but the lower rolling resistance should help them move a bit quieter, and be better on fuel. If all else fails drop to 32, the factory specified default. It'll use more fuel, but it can't hurt to try. Ideally you want a Michelin or similar on there as discussed previously. Anything bar a P7 really, they just don't suit the car imho.
Mine is as quiet as a mouse.
I can hear the tyres if I turn the radio off but it is only a slight whoosh and not a rumble.
Also when it goes onto two cylinders nothing seems to change.
If I go out in this, it's a bit noisier
Cold Start short.mp4
Edited by vfrvrs
