Door Windows
Just noticed that my Superb Mk3 SEL Executive can't open or shut the door windows from the key fob like my previous Mk1 & 2 Superbs could do.
Is this something that can be switched on via software?
Thanks.
Could it possibly be related to the rain sensor setting?
That can certainly be coded and I believe OBDEleven has an app for it on the Superb III MY2017. My MY2017 L&K already has it.
Edited by TerryMcK
Try looking at:
Car > Settings > opening and closing > (Window operation) Convenience opening:
’All windows’ needs to be selected (if available)
Edited by penguin17
Thanks for all the replies I will investigate further :-)
Mine certainly does it so must be selectable within the normal menus and should not require vcds or similar to make work.
Mine also works
7 hours ago, penguin17 said:
Try looking at:
^^^ what he said ^^^
no need for coding, nor is it rain sensor related.
Checked the: -
All already selected but windows still don't open with a prolonged hold on the unlock button or don't shut when holding lock button.
I will try my other keys, (came with 3 sets), tomorrow or later today :-)
Thanks once again for all the replies.
Does the sunroof close this way at the sam time? I heard that it doesn't so might need to be careful :)
Hi all, I have had a play and re-read the manual and could not still open or close the windows using the key fob.
I decided to reset the Driver 1 personalisation to factory defaults and set up Driver 1 to the key I was using and now the windows open & close on the key fob.
Thanks for all your assistance and guidance :)
Hi Tony, my car hasn't got a sunroof fitted so can't comment on this.
My sunroof closes if I press and hold the lock button on the key.
Hi
does yr sunroof completely open via the fob (mine just tilts)?
regards
n
5 hours ago, poundygp said:
Hi
regards
n
I didn't realise this, but mine only tilts too.
