Need help with vcds .can't lock my car
Missus is gonna kill me as it's her car but I've gone onto vagcom to see if I can activate any turning/cornering light and found these to be unticked it altered the code from 20 to 02 so I copied the full code and pasted it and pressed do it .
It said code accepted .but I stared the car up and turned the steering wheel .and no cornering light .now I've got the parking lights illuminated when the switch is on zero all the time and my full central locking doesn't work including the inside button .I've no idea what to do next ....
I've been back into central electronic on vag and selected to until what I had ticked but to my amazement there already unticked I'm totally stumped I just need the original long code I think
I should have wrote it down like it said
Did you do an autoscan and save the log before you changed anything?
i did a scan but didnt save the log  doh!!! schoolboy error , its very strange that altering somthing on the fog lights and its made the complete central locking to pack up and the parking light to work all the time apart from when the engine is off
Can you post a full autoscan as it is now.
Hi .yes I can in the morning  .are you around then.cheers
VIN: TMBFN25J1D3149918   License Plate:
Chassis Type: 5J-SK25 (6N0)
Scan: 01 03 08 09 15 17 19 25 2E 37 44 56
VIN: TMBFN25J1D3149918   Mileage: 79830km-49604miles
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
2E-Media Player 3 -- Status: OK 0000
37-Navigation -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
56-Radio -- Status: OK 0000
Address 01: Engine (J623-CBZB)       Labels:. 03F-906-070-CBZ.clb
   Part No SW: 03F 906 070 HK    HW: 03F 907 309 AK
   Component: SIMOS10.22AH10 2693
   Revision: --H10---    Serial number:
   Coding: 00110056200400080000
   Shop #: WSC 13765 031 00047
   ASAM Dataset: EV_ECM12TFS02103F906070HK 004003
   ROD: EV_ECM12TFS02103F906070FP.rod
   VCID: 72EAE254A5AF20D697-8026
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6R0 907 379 AR    HW: 6R0 907 379 AQ
   Component: ABS9.0 front  H01 0001
   Serial number: --------------
   Coding: 40DC447D212700C9021D226A845900000000
   ASAM Dataset: EV_Brake1ABS90BOSCH 003017
   ROD: EV_Brake1ABS90BOSCH_VW25.rod
   VCID: 0E1296A4D157643613-805A
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 5J0 820 045 D    HW: 5J0 820 045 D
   Component: Man AC        H02 0202
   Revision: 0004SH02
   VCID: 2642CE0451E70C76CB-8072
Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08x-09.clb
   Part No SW: 6R7 937 087 M    HW: 6R7 937 087 M
   Component: PQ25 BCM      H30 0555
   Revision: -1------    Serial number: --------------
   Coding: 980B3808C9240092208A002C2B08C10040400F6000000002001000000000
   Shop #: WSC 22007 098 90986
   VCID: 4E9256A419D7243653-801A
   Subsystem 1 - Part No SW: 6R0 959 802 AN    HW: 6R0 959 802 AN  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  006 5210
   Serial number: --------------------
   Coding: 030000
   Subsystem 2 - Part No SW: 6R0 959 801 AL    HW: 6R0 959 801 AL  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  006 5210
   Serial number: 13102561130411215759
   Coding: 020000
   Subsystem 3 - Part No: 5J0 951 172
   Component: DWA-Sensor      H03  H03 1211
   Subsystem 4 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H05  H05 1501
   Subsystem 5 - Part No: 5J0 951 172
3 Faults Found:
01229 - A/C Humidity Sensor (G260)
            004 - No Signal/Communication
             Freeze Frame:
                    Fault Status: 01100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 79826 km
                    Time Indication: 0
                    Date: 2018.04.08
                    Time: 18:21:32
00208 - Terminal 30 for Glovebox Illumination
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 167
                    Mileage: 79826 km
                    Time Indication: 0
                    Date: 2018.04.08
                    Time: 18:21:32
01312 - Powertrain Data Bus
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 2
                    Reset counter: 168
                    Mileage: 79826 km
                    Time Indication: 0
                    Date: 2018.04.08
                    Time: 18:21:28
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10AirbagT2C H10 0020
   Revision: --------    Serial number: 003GX01P8ZUM
   Coding: 003243
   Shop #: WSC 13765 790 00047
   ASAM Dataset: EV_AirbaVW10BPAVW250 A01001
   ROD: EV_AirbaVW10BPAVW250_VW31.rod
   VCID: 4A9A5AB4EDBF08160F-801E
   Crash sensor for side airbag: driver side:
   Serial number: 3495RRB400K50GJ2I1IH
   Crash sensor for side airbag: front passenger side:
   Serial number: 3505RRB400K50GJ2NOU6
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb
   Part No SW: 5J0 920 941 E    HW: 5J0 920 941 E
   Component: KOMBI         H05 0306
   Serial number: 00000000000000
   Coding: 410A00
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04113
   ROD: EV_Kombi_UDS_VDD_RM09_A04_SK25.rod
   VCID: 2D5031287C113F2E0A-8078
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R7 937 087 M
   Component: GW-K-CAN TP20 H30 0555
   Revision: -1------
   Coding: 032300
   VCID: 70EEE85CA3A312C661-8024
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H05 0306
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03009
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6ADAFA348D7FE8162F-803E
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 F    HW: 5N0 035 342 F
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664691472
   Coding: 020100
   VCID: 2A5A3A3445FF2816EF-807E
Address 37: Navigation (J794)       Labels:| 1K0-035-27x-37.clb
   Part No SW: 3T0 035 192 M    HW: 3T0 035 192 M
   Component: RNS315-EU   H60 0324
   Serial number: SKZAZ2N0261568
   Coding: 040004110406000001000002
   ASAM Dataset: EV_RNS315EUV2UDS 001705
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 387E107C83538A8669-806C
   Data medium:
   Subsystem 1 - Part No: 3AA 919 866
   Component: EUR_W_V4  0050
Address 44: Steering Assist        Labels: 6Q0-423-156.clb
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 10140
   Shop #: WSC 13765
   VCID: 306E285CF72352C621-8064
End-------------------------(Elapsed Time: 01:58)--------------------------
Edited by Jamesey
First thing would be update to the latest version, then rescan.
i cant update it for some reason , the seller told me not to or it wouldnt work?
just an update ive lost electric windows , heated mirrors , remote locking and ive got a brake light fault , shes gonna kill me lol
So it's a pirated version. ;)
You should consider buying a genuine tool.
Dunno it looks real . .it was £100 Its got all the rosstech markings on it
Pop over and register on Ross Tech Forum and ask them to verify it. I doubt you'd get a genuine one for £100 though.
No it wasnt real ...cost me £60 by a vw geek to sort altering 1 tick in the longcodes wiped nearly every electric function out
So all's well that ends well?
Yes he said I could have screwed my bcm unit up . Not messing with it on the coding side anymore .lesson learnt
