VCDS Key Code HELP !
Hi All
I have a 2005 Skoda Fabia 1 - 1.2 Classic.
When I purchased the car I only received one key with it.
I have had another key cut so I can open the doors, however the key code provided with the key didn't work.
I do not have the original key code in the documentation which came with the car.
Does anyone know if there's a way of extracting the key code from VCDS, also how do you code in the new key with the code.
There is a program called VAGtacho which will read the immob code from your cluster. Then you can code the key using VCDS once armed with the code. :)
I'm thinking of investing in VAGtacho. 290 euros though!
Devonutopia we have VAGTacho & its a useful bit of kit
Its money well spent :thumbup:
vagnostics - I see your in Lincolnshire, I will have to visit Lincolnshire at some point this year - as coding the key in isn't a priority, is extracting the key code and coding a new key somehting you could assist with ??
Yes we could extract the PIN & code the key to your vehicle...Just give me a call on 01724 854769 when your due to visit
