GPS Columbus unit - signal?
Hi,
The GPS on our Columbus unit no longer works as its cant find our current position.
Looking at the number of satellites it can track it shows 0/11 all the time :(
I'm on the impression at worst case this is just a fault antenna but not sure?
My car is in for a service next week, just booked it; and I mentioned this issue believing they could do a check at the same time as the service and advise on cost to fix.
Disappointingly they've advised me if I want them to look at this, it'll required an additional diagnose charge of the standard £90 to plug into a computer for the checks?!
They advised me if I'm sure its an antenna, they can quote for this and do this without the diagnose check; but obviously if it still doesn't work I'm still liable.
I've always been given a quote for diagnosing stuff under a normal service....any advice on this one?
Cheers,
Hung
Garage money maker, ask them if it is the antenna will it show a fault code for £90?
I don't think so.
Sounds to me the antenna is at fault.
had this on the Octavia blackline,usually a faulty  antenna on the back of the unit or the roof
Anyone know the costs of the antenna part; and what sort of labour costs n durations are we talking about?
I'm 90% sure it probably is....but that 10% ?
Having to pay £90 for a check is robbery....despite already doing a service.
Edited by Hyeung
if you warranty has expired just get a good auto electrician,when mine was done it was a new car and repaired in under an hour
Buy a £5 gps antenna off Ebay and fit it above the unit in the dash. Takes about 10 minutes and will 99% cure the fault. If it doesn't then your radio board will be fried usually.
Check the antenna and clean any connections you can before you get a new one. My radio stopped working in a previous Skoda and it just needed the antenna cleaning and reattaching.
Lost mine through a very powerful Car wash! Replace the roof antenna and all is fine :)
I had a similar issue to this.  Turned out the battery voltage was dipping low enough to reset the Columbus.  A new battery sorted it....
Amdy
