Low oil pressure warning
Hi all after a bit of advice I have just noticed that when I drive in certain modes a low oil pressure light comes on and bleeps at me 3 times then when I drive below 20mph it clears it self or when you switch the engine off I had a complete oil change and engine flush just not sure if it’s a sensor or pump issue
Who did the oil and filter change, and are you sure the oil filter is not overtightened, and the old oil seal is not still on as well as the new one>
It was doing it before I had the complete change it’s been good since I had it done untill today
