Skoda Front Assist......is there a retrofit available
Don't know it this helps after such a while, but have managed to add ACC to my car that already was factory fitted with FA. ACC works for speeds starting from 30 kmh, under that it gives a warning to brake (I suspect if I do nothing, FA kicks in, but I'm not eager to try :) ) For full ACC (stop car) a different ABS pump is needed and this becomes much more expensive and labor intensive.
Parts needed: ACC compatible stalk + new cover under the steering column and some online coding / SWAP codes. I already had the proper steering wheel module. All is working, set distance, ACC is on and no errors.
So, for factory fitted Front Assist card, this retrofit is relatively easy to do with someone that knows the entire procedure.
