Led rear sidelights
Are there any workarounds for when you pit led bulbs in rear sidelights. I did it and now bulb on and message to check left and right sidelights. Is there any way to put one inline 8 ohm resistor to over one comple side of the 3 bulbs or any other thing
You could recode the settings that the taillights are not taken into consideration regarding the faulty bulbs (VCDS can't do that, maybe VCP - but not sure, ODIS-E can do it)
Ok thanks i only have delphi system would that do it
No chance, if VCDS can't work that out, which is the closest they got to the factory diag software, all the others are miles away from doing such fine reprogramming
Might be worth adding where your based too as a local member might be able to help.
In northern ireland co down
