LED high rear lights?
Does anyone have these?  If so what’s the actual different between high and low LED lamps?  The configurator has no description, just a picture which doesn’t look any different?
On the facelift, the LED low has a thin single C shape Led strip. On the LED high variant, it's a much thicker C. Reverse, indicator and fog still all halogen I believe.
High looks like this:
Can't find an image but the low led is in this video:
Thanks for that. If that’s all the difference I don’t think it’s worth £155.
The high ones do look much better and more modern, I'd personally spec them for a relatively small cost.
i think they missed a trick with sweeping indicators. disappointing really.
i might try to mod a set but i'm not sure whether to go front or rear. I have the correct sweeping strip which can be used as a drl as well. I was going to build it into the reflector but blanked it instead. just need a cheap/free cracked light to try it on, a new one is too much to experiment with.
