Skoda Octavia VRS 2.0TDI (CUPA EA288) high oil consumption
Today I didn't do anything. I had no time. But I stopped by and tried to start the car. It fired right up.. After a few minutes of idling it just started to run funny (no noises) and just died. I couldn't start it back up so I'm leaving it overnight and check again tomorow. A friend of mine suggested that maybe the oil pressure regulator is stuck and delivering too much pressure and the tappets too expand too much?
  • Replies 228
  • Views 181.2k
  • TadyTheFish
    TadyTheFish
    I ordered new  - Head gasket - Head bolts - Head module bolts (18pcs) - piston rings - conrod bearings + bolts - main bearings + bolts - thrust bearings - crank
  • Finally found what was causing high oil consumption for my VRS, please see attached picture, this how piston one looked for car with millage 160K. And one more thing, don't do long service intervals,
  • CristianCCI
    CristianCCI
    Cupa is euro 5 and Cuna euro 6.
Maybe something wrong with egr system.
Hmmm maybe something worh checking out but I doubt it since this is an low pressure system. I takes the exhaust after DPF and routes it before the turbo
I made a new thread about this since i basically highjacked this one 🙈 maybe throw some ideas there 😁 and thank you for your help!
https://www.briskoda.net/forums/topic/511732-mk3-vrs-tdi-starting-problem/
Edited by TadyTheFish
  • 3 months later...
Well in march i did the service on my Octavia... She has done 4500km since then and the oil droped for about 2mm so my work was a success 😁
