Both rear fog lights, How-to GUIDE!
@cristianene Do you have a picture of both left & right connectors to see cable colors where you plugged (out and in) ?
Thanks for your help !
Edited by Bap33
  • 9 months later...
  • Replies 53
  • Views 31.2k
  • Some must and nice to have prerequisites:   Musts: Cable: 1.5-2m Torx T25 screwdriver Electrical tape Prying tool (or a flat screwdriver with some electrical tape on it s
  • Done!   YT video
  • So, it didn't go exactly as planned, but meh!  The connectors I found, the multicolored ones are not good. It should have been one size bigger. Lucky for me, the mechanic had some spare cables ly
Does this work for reverse light as well?
 Reverse light up on both outer clusters already
if you look at his post is not so hard to see (the post with many pictures) brown is ground, grey is fog light and grey-red is for extended tail lights. to add to it if anyone interested the connector that comes from factory with 4 pins is 3B0972722 also useful for who needs to retrofit extended tail lights.
Thanks, I’ll have a look at it. 😉
  • 7 months later...
So if I'm reading this correctly I should just need to splice into the grey wire on the right cluster with a 1.5/2m wire, add a connector to the end of that wire and plug it in to the left cluster plug with only 2 wires? If so, what additional connector is needed, and where is it plugged into?
This is a great how to and solves an issue many have had with Mk3 superbs, it just needs fine tuning with the finishing details to help others carry out the DIY mod.
Can anyone suggest a connector they used and where they connected it to?
  • 2 years later...
BOTH REAR FOGS FOR 2020+ MODELS
I’ve The 2022 Facelifted Superb With The All LED Tail Lamps Setup
I Was Scouting For A Long Time To Do This Mod Too As Only A Rear Right Side Fog Light Made It Look Like A Cost Cutting On Their Flagship Car!
Then I Came Across This Post & Wanted To Give It A Try
Firstly Let Me Tell You That I Tried All VCDS Codings & None Of Them Work
NO VCDS CODING IS REQUIRED FOR IT
It’s Just A Case Of Hardwiring It From The Right Lamp To The Left One 😁
And As No Proper Way Is Listed Anywhere For 2021 Onwards Models And Our Connectors Are Totally Different From The Previous Gen Lamps, So Let Me Share The Whole Process With You Guys 🤪👍🏻
STEP 1 -
Unclip The Boot Closing Button & Remove It Aside, And Then Remove The Rear Trunk Liner (Which Is Held In Only By Metal Clips), So Pull It Apart In Downward Direction As Shown Earlier In This Thread With Plastic Trim Removal Tools
STEP 2 -
Find Both The Connectors For Both Left & Right Lamps
As You’ll Notice From The Above Pictures, The Left Light Connector Has 5 Wires Going To It & 1 Empty Slot In The Connector
Whereas, The Right Light Connector Has All 6 Wires & No Empty Slots
STEP 3 -
Take 2 Pin Crimp Connectors
(You Can Find These Easily In Old Computer Cables, Just Pull Them Out Of Any Lying Sockets)
See The Attached Picture For Reference
STEP 4 -
Attach Both Of These Connectors To Both The Ends Of A 1-1.5m Long Wire And Solder Or Electrical Tape It Properly!
STEP 5 -
Now It’s Just The Matter Of Putting One End Of The Wire Into The Empty Slot Of The Left Connector (Refer Step 2) And The Other End Of The Wire Gets Joined Into The Bottom Right Light Purple Coloured Wire Which Is For The Fog Lights!
Now Pack Everything Back To As It Was
AND VOILA YOU’RE DONE! ✅
Enjoy Both Fog Lamps Working With The Same Switch 👌🏻
I Wonder Why They Provide Lights On Both Sides But Different Wiring 😞
because safety, brake lights are better visible with single fog
Yes I Totally Agree With That 🤪
But For The Superb The Brake Lights Are On The Outer End On Both Sides
And Mainly It Is For The OCD Freak Inside Me 😝
  • 8 months later...
Do you know if this 'how to' also apply to a MY2017 Mk" (non FL version)?
Yes, This Is Done The Same Way On Pre FL Models Too, Just A Wire Needs To Be Run From The Right Coupler (With 6 Wires) To The Left One (With 5 Wires & 1 Blank)
Hi,
Does anyone know the reference of the OEM harness repair kit? I mean, one with a long enough cable to do the same mod as in this thread? 😁
TIA.
Yes, certainly. I did that to our 2017 reg Superb. No coding or anything like that required. Everything works as it should.
Errr... I think I have bad luck. It does work for me. 🙄
I have 3 wires on the left (4 slots / 1 empty on the connector) and only 2 wires on the right (4 slots / 2 empty on the connector). Note: I own a LHD Estate Mk3 (built in Q4 2017).
Nevertheless, I've noticed that the right rear light set (bolted on the tailgate) has an unconnected male pin, which I assumed to be for the right fog light.
I thought it would be as easy as you describe guys, but it ain't. I've made a connection on the Left rear fog light wire. I've checked that the voltage changes at the other end of my wire upon rear fog light activation: that's fine.
I've made a temporary connection to check everything is OK before final assembly, but the right rear fog light doesn't turn on... 😤
May be the male pin is a bit rusty. I forgot to check this point... 🤔
Conclusion: Back to square One... 😬
Has anyone done this on an estate version? Examples above are only for hatchbacks. May be there's a trick I miss?... 🤔
I'll also check my VCDS coding, because, I had tried (unsuccessfully *) to activate my right rear fog light using VCDS codes for RHD a couple of years ago. I'm quite sure, I' had put everything back to original LHD coding. But a double check doesn't cost much.
(*) I now better understand why, since the bulb😁 is not even wired...
Well, any help would be much appreciated. ITA
On our RH drive Superb hatchback, I bridged our LH fog light from the RH cable (white/grey in colour), successfully. Original rear inner light connector had 3 cables on the RH side, and only 2 cables on the LH side. I've recently retrofitted the original 2017 lights to 2020 animation lights.
This why I'm doubting... Could there be something different on LHD estate version?
LH fog light has a white/grey wire too. I also tried to bridge the RH fog light from this cable but it remained off..
I'll give another try later.
I don't know how the rear lights wiring on LH drive models looks like, but I would guess that it shouldn't be that much different to that of RH models.
If all attempts fail, it might be worth considering another check with a local motor vehicle electrician.
Also, ensure the fog light you're trying to connect to works. On ours, with the lamp off the vehicle, I firstly tested all individual lights (inside the lamp housing) by carefully connecting a 12V battery to the lamp's negative terminals (brown cable), then checked which light came on when the positive line from the testing battery touched individual pins. It's safer to use an 'automotive circuit tester' to touch individual pins to avoid accidental short circuiting. Attached here is a picture of how I linked our rear fog lights from the RH (white/grey cable) to the left side on a RH drive Superb Mk III model. Be patient and good luck.
I´ll double check everything.
That's the best way to go about it, you'll eventually get there. It's not easy, but it can be done. Like you've said, start off by double-checking your individual lights first before connecting things up. And also, make sure your connector terminals and pins are sitting correctly in their individual housings. Please let us know how you get on. If you live around Midlands area, give us a shout for further assistance, if needed.
Well, I fear Midlands is bit far for me, since I live in France ~20-25km from Paris. 😁
Nevertheless, thanks for your proposal! ;)
I've been checking all my VCDS codes tonight. The good thing is that it's all set as it should. I was almost sure, but it's better to double check. When I tried to make the VCDS mod I had found on this forum, I had put all settings back to original values once I noticed the mod doesn't work for me.
Hence I "only" need to try the cabling again. But first I'll try to light up the right rear fog light on its own (ground with brown cable / +12V on unplugged pin).
I'll come back here when I find time to try again. ;)
Thanks.
Sounds like you are playing it safe by testing the right fog light on its own whilst on an unplugged pin. It would also be worthwhile repeating the same testing to the left fog light, to ensure it works. If they both work, then there shouldn't be any reason why the cable bridging would not work for both fogs.
  • 1 year later...
Thanks.
@Bap33 I Think You’re Making The Same Rookie Mistake That I Was Making At First 😝
Just Remember That While Testing Whether The Rear Fog Is Working, The Boot Lid Has To Be Closed & Latched And Then Only The Rear Fog Lights Up 😝
I Wired Everything Perfectly & It Wasn’t Turning On
It Took Me A Good Half An Hour To Realise This That The Boot Has To Be Closed First Just Check On That Please 🤣🤣
Hi @47Sportline,
You may be right.
But if I remember well, I think I also made a test with right rear fog lamp block disassembled and plugged, directly on a 12V battery.
I've switched to something since else since that time, considering it would not work.
I will most probably reconsider activating my right rear fog lamp. 😁
  • 7 months later...
I have wired the 2. fog light on our RHD 2023 SIII estate.
I was pretty easy as described above. I had a look at the wiring diagrams before and it seems the same on LHD as on a RHD, just in reverse.
I checked the left fog light first. There are 2 tiny LED elements in the fog on both sides when you look into it. I also checked for function first with a pin and loose wire and the fog light is still present on the left. I soldered the spare wire onto the grey / white wire in the 6 wire connector on the right and routed it to the left fog light connector / plug. I still had some spare pins from a previous retrofitting project.
Above people mentioned that the fog light only works when the boot lid is closed.
It can be coded that the fog light can be on when open.
Coding in in Stg09 in Adaptations 07
Look for NSL - Nebelschlußleuchte (foglight)
In the line "Lichtansteuerung" only if closed you can code to open.
[VO]_Leuchte26NSL LA72:
[LO]_Lasttyp 26:
[VO]_43 - allgemeine LED
[LO]_Lampendefektbitposition 26:
1C
[LO]_Fehlerort mittleres Byte DTC-DFCC 26:
2F
[LO]_Lichtfunktion A 26:
[VO]_Nebelschlusslicht wenn kein Anhaenger gesteckt
[LO]_Lichtfunktion B 26:
[VO]_nicht aktiv
[LO]_Dimmwert AB 26:
100
[LO]_Lichtansteuerung HD AB 26:
[VO]_only_if_closed
[LO]_Lichtfunktion C 26:
[VO]_nicht aktiv
[LO]_Lichtfunktion D 26:
[VO]_nicht aktiv
[LO]_Dimmwert CD 26:
0
[LO]_Dimming Direction CD 26:
[VO]_maximize
[LO]_Lichtfunktion E 26:
[VO]_nicht aktiv
[LO]_Lichtfunktion F 26:
[VO]_nicht aktiv
[LO]_Dimmwert EF 26:
0
[LO]_Dimming Direction EF 26:
[VO]_maximize
[LO]_Lichtfunktion G 26:
[VO]_nicht aktiv
[LO]_Lichtfunktion H 26:
[VO]_nicht aktiv
[LO]_Dimmwert GH 26:
0
[LO]_Dimming Direction GH 26:
[VO]_maximize
[LO]_Lasttyp 26:
1C
2F
[VO]_nicht aktiv
100
[VO]_only_if_closed
[VO]_nicht aktiv
[VO]_nicht aktiv
0
[VO]_maximize
[VO]_nicht aktiv
[VO]_nicht aktiv
0
[VO]_maximize
[VO]_nicht aktiv
[VO]_nicht aktiv
0
[VO]_maximize
Wonderful Sir!
This Is A Wonderful Community Which Makes All Of Us Learn Something New Everyday! 😊
  • 4 weeks later...
Hi, i've only just found this site and it's being so informative...
I have moved to France and my skoda scout 2016. I need to change over rear fog lights from Right to left. It's just failed the French MOT equivalent. CAT. Does anyone please know how I can overcome this issue and have the wiring changed.
Thank you for your help
