Fabia Mk I engine removal howto
Skoda Fabia 1999-2007 1.2 6V/12V engine removal (propably about same on others too)
Battery fuse box
Battery
Battery holder (3x 13mm)
Main (+)-cable (10mm)
Ecu connector (big one)
Other big connector near left wing
Both wheels
Inner wheel arches
Engine under plastic (lot of T25 torxes)
Remove plastic rivets under bumper
Alternator cable
Starter motor cable
Lambda sensor cables
Engine earth cable
Reversing lamp switch cable
Cooler fan connector
Temperature switch connector
Detach downpipe and 1-2 exhaust pipe hangers
Drain coolant from left side of radiator
Inner driveshaft flanges (6x 8mm XZN x2)
Remove engine under support (2x 16mm)
Drain clutch fluid (11mm)
Gearstick cables
Detach air pipe from brake booster
Disconnect coolant reservoir
Disconnect two big radiator hoses
Detach heater matrix hoses
Disconnect fuel hoses
Remove both headlight washer covers
Unscrew but do not remove washers' screws (4x T20)
Disconnect washers from fluid reservoir (pump)
Remove bumper upper screws (2x T30)
Remove bumper
Remove bonnet cable
Detach headlight connectors
Remove side screws (2x T30)
Remove locking plate screws (2x 8mm XZN)
Remove bumper plate (6x 8mm XZN)
Remove front section of car
Remove motor heater cable if exists, or anything i forget to mention
Support engine with motor hoist
Remove both engine supports
Remove engine (careful with wiring loom)
  • Sponsor
Nice list.
That's for a car without A/C, it looks like?
For cars with A/C there are some instructions including what to do with compressor here: https://workshop-manuals.com/skoda/fabia-mk1/power_unit/12/40;_47_kw_mpi_engine/engine_assycylinder_blockcrankcase/removing_and_installing_engine/removing/
Looks like you can leave the refrigerant circuit unopened if you're careful. Also suggests removing the clutch slave cylinder from the gearbox to keep that hydraulic circuit closed.
Anyone know what is this connector ? For some reason can't figure out where it goes..
  • Sponsor
Must be for reverse light switch, I think? Two contacts?
Switch is low down on the front face of the gearbox.
No. It's already connected. And that doesn't fit to it..
  • Sponsor
Wire colours?
Alternator L and DFM connections next guess. Does your battery light come on with ignition?
Edited by Wino
Oil pressure switch?
14 hours ago, Wino said:
Wire colours?
Brown + blue
Battery light does not come.
6 minutes ago, DtiJ said:
Brown + blue
Connect it to the alternator then.
  • Sponsor
I'm not sure if that's the one that goes directly into the back of the alternator, is it long enough?
If not, you should find the mating half of that connection on a steel bracket hanging off the front of the gearbox, near the starter motor. Lambda sensor connectors are on the same bracket I think, but I'm not too familiar with the exact layout on the AWY/BMD engines.
It's not long enough and alternator already is connected. But alternator light still does not come when ignition on...
There is maybe some mismatching with new engine wiring loom. I'll extend wire to connect it to alternator and see what happens.
My car is little bit mixed up with AWY and AZQ...
AWY has alternator connector in engine loom? and AZQ has it in alternator/starter/lambda loom? So now I have both, great :D
  • Sponsor
I can study the wiring diagrams soon, when I get home, but certainly on most Mk1 Fabias there is a socket-to-plug section within the alternator connecting loom, which finishes at the bracket on the front of the gearbox, then there's a socket mating into this that is part of the engine bay loom.  Can you identify this plug/socket pair on the bracket on the gearbox? Are the wires all unbroken either side?
Worth trying, yes, but maybe follow the wires from the connector that is plugged into the back of the alternator and see where they currently go to first.
  • Sponsor
Looks like the AWY arrangement has the two wires from the alternator connector going to the 14-way connector on the left suspension turret next to the main battery earth, instead of what most Fabias have. Pins 3 and 4.
Now my alternator 2-pin connector comes from same loom as that unconnected plug :huh:
I'll attach pictures of
- AWY engine loom (alternator end). Notice it's next to ignition coil connector.
- AZQ engine bay loom (alternator end). Picture shows also both lambda connectors.
I have now connected AWY engine bay loom alternator end to my AZQ engine alternator -> instrument panel not showing battery light, however alternator works (14V-15V on idle at battery)
Am I right if I say I'm missing extension wiring between alternator and bracket next to lambda connectors?
Edited by DtiJ
  • Sponsor
Sorry, I'm being a bit slow here, but what engine did the car originally have, and what year is the car?
What engine does it now have? (From what year?)
I'll draw a couple of quick sketches of how the wiring goes in AWY and non-AWY cars and photograph it. Back soon.
Originally AWY, car is 2002, now AZQ (from 2003).
  • Sponsor
OK, so yes, I think you just need to get the two wires from the connector in your second picture to get to the alternator.
I started a sketch, but I'm crap at drawing.
  • Sponsor
Try these. OBSCU is the Onboard Supply control unit in the cabin, ECU is engine ECU.
what is purpose of that brown? and blue?
i connected them like that azq picture but no battery light when on ignition. I left everything unconnected but no battery light. Alternator gives 14,5V+ on idle.
IS THERE EVEN battery light in instrument panel?!
  • Sponsor
Blue gives the alternator field coil some current to help it to start generating, brown tells the engine ECU how much electrical load the alternator is experiencing.
On some petrol Fabias/Polos neither function seems to be essential. The voltage regulator on the alternator seems to be able to start the generating without the blue wire. The ECU doesn't appear to do much with the load info. Diesels seem to be more vulnerable and often don't start generating if the blue wire is broken.
There is a battery light though.
Measure volts at each of the pins of the alternator loom connector with ignition on. Blue wire will show 11-12V and brown close to 5V or close to 12V (varies with engine ECU type, I think) if both wires are intact all the way to their destinations.
I disassembled loom starting from alternator, and blue+brown goes to bracket at gearbox, and ends to connector. So i am missing wires between connector and ecu+obscu. I'm not going to start building them, so I think car is fine now. Maybe I add ignition +12v to blue wire if there is good spot doing that. But it's not urgent as alternator works,
  • Sponsor
Don't just connect ignition 12V to the blue wire connection. It would need a reverse current blocking diode and current limiting resistance to avoid problems.
I can give you more details about exact destinations of the two wires at the ecu and firewall connectors later today.
hello. pins 3+4 are not existant in 14-way connector.
I think I have to find alternator light pin from instrument panel?
  • Sponsor
There isn't one. The alternator excitation comes from the OBSCU. Which looms have you changed in the engine bay, everything?
Engine loom and short loom which is front of engine
