Kodiaq Workshop Manuals
2 hours ago, StevieDexter said:
Fantastic. I've downloaded lots to use. But I cannot find anywhere about how to remove the rear light clusters on the body work and the tailgate. Which one would it be in? Thanks
As the Kodiaq version doesn't appear to be available, try the Karoq version instead which is likely similar - details here:-
  • Replies 62
  • Views 42.3k
  • See if this works?   It's a big file though so will likely take some time to download, it contains all the files listed above in my earlier post.   A big thumbs up to @Arkaig for t
  • I've got all of them...     Unfortunately they're mostly over the max Briskoda 20Mb upload limit.   I asked if there was a way around the upload limit a few weeks ago, b
Excellent. Thank you!!!👍
does anyone have access to erwin?  I am looking for a drawing of how to disassemble the trim panels in the trunk of a Kodiaq 2020 model
You can access Erwin yourself at a cost of about €8.40 per hour:  https://erwin.skoda-auto.cz/erwin/showHome.do
Edited by Arkaig
  • 2 years later...
Thank you very much.
  • 9 months later...
Thank you for documents, is there an dedicated document regarding trailer hitch (towbar)?
I'm searching for connections of trailer socket, release button, trailer detection module and body control module?
Try:
Section 9 - page 245 Trailer coupling
Alsp:
Section 11 - page 137 Trailer coupling
Also:
Section 59/1 Trailer coupling
Edited by Arkaig
Additional reply
7 minutes ago, Arkaig said:
Try:
Thank you, I've seen that, but I'm looking for info on connecting wiring that goes from trailer recognition module to BCM (body control module) near fuse box at the steering wheel. Something like this?
My original reply amended further - hope that's of assistance.
Hi.
I can share you de Karoq Towbar.
It’s similiar.
I think can help you.
Accesorios - Towbar - GDW - Instrucciones de Montaje G2281.pdf Accesorios - Towbars Instrucciones de Montaje y Codificación 3DG0317_748343_SK_Karoq.pdf Accesorios - Towbar - ECS - without towbar prepared connector VW146B1SKA.pdf
