Felicia 1.3 MPI - Slow Starter Motor
@KenONeill - I've just gone and taken new measurements. My earlier ones were off a little, here's new measurements:
Off: 12.7 V
Idle: 13.1 V
2,000: 13.6 V
5,000: 13.4 V
Is it possible to service the alternator brushes or slip rings if this is the problem, or easier to buy a reconditioned alternator?
  • Sponsor
Off values are good, running values are rather low, 14+V is much better.
Try measuring the voltage directly at the alternator output stud, with the negative meter probe on a bit of scratched clean alternator body casting.  If the charging voltage is significantly higher when you do so, it would point to a poor connection somewhere in the high current leads, either the positive output cable, or the main earth cable between engine and chassis/battery negative.  This sort of thing can often be resolved by simply disconnecting and cleaning the contact areas of the wire crimps on the ends of the heavy-duty leads.
Buy a reconditioned alternator.
@Wino Okay, I’ll check the alternator and see if there’s any difference in voltage.
@RicardoM I’m looking at alternators but am struggling to find many of my older low ampage type for a reasonable price.
There are many of the VAG Bosch versions with the regulator hidden behind a rear plate. Would this be okay for me to use, or must it be a direct replacement?
The dropping voltage at higher rpms is a very common felicia problem and it's caused by one of the bridge rectifiers starting to fail it an pretty hard task to replace them but it is doable I did that on my felly and it's now perfectly fine
Why low amperage? Go for the 70A type no worries.
@Lewys - Seconded what Ricardo says about fitting a higher peak amperage alternator when you need to (ex)change anyway.
Thanks for the info - I’ve ordered a reconditioned higher amperage Bosch alternator.
@Wino - I checked the voltage directly at the alternator and there was only a 0.1 increase in charging voltage, which should rule out a connection issue in the leads then.
