Peculiar Interior Light Issue
Hi All.
In the 5 minutes my car was parked up while i went inside, put some laundry in, and left again my 67 plate Citigo developed a strange fault.
Whenever I have more than mild acceleration, my interior lights comes on.
My suspicion is that there's a loose wire somewhere. The door light doesn't illuminate on the instrument cluster, so I don't think its a door switch.
I tried reversing gently into a kerb, and that made the light come on as well, and it stayed on until I reversed backwards (bumping the car was a jolt forwards, needed to reverse to undo the jolt)
I also found the interior light was staying on when I close and lock the door, but the hazards don't flash which I thought they used to?
As it's still under warranty it'll be visiting the dealers, but I thought you'd all like to see this bazaar new feature.
KR
Rob
mine does it after a wash. appears to be the switch that senses the boot being closed
18 hours ago, RobMurrant said:
Hi All.
KR
Rob
That’s a strange fault :D
Perhaps the fault is that the rest of the Citigos don't have it!
A peak acceleration light! Brilliant!
