build spec
how do i get the build spec and what is the code for BT fitted when new?
Ive found 2 missing sections of carpet/underfelt under the drivers seat that looks like something was there
You will have a sticker in the boot with your VIN, colour code.... and lots of 3-digit codes. These are PR-codes and you can check in lies or some websites what these codes mean.
But not every spec seems to be on your PR code sticker - at least mine was missing some before I started to add bits.
This is from a file I downloaded - attached.
PT5 Handyvorbereitung (Bluetooth) mit Komfort-Mittelarmlehne
pr-nummerntabelle-vw-audi.pdf
Danke
BOOK!
isnt there a list in the owners manual?
Edited by lichfielddriver
Brand SKODA
Model SUPERB AMBITION GREENLINE
VIN TMBBJ73T3D9045200
Check digit Ok
Sales id 3T4211
Permanent link https://carinfo.kiev.ua/cars/vin/skoda/vin_check?su=huqc-_fkb5je
Production date 2013-02-27
Model year 2013
Engine code CAYC (TDI CR)
Engine number 000
Engine volume, L 1.60
Number of cylinders 4
Power, KW 77
Power, PS 105
Colour of body 8E (SILVER: reflexsilver metallic)
Trim TF
Gearbox code MDM (5S)
Country of sale 000 ()
Custom options
Parameter Value
E0W Special editions: Special edition
1PD Lockable wheel bolts: Wheel bolts with anti-theft protection (unlockable)
ND0 Adapter (for trailer hitch): Without adapter
1CM Vehicle class differentiation units/platform components: Vehicle class differentiation 3T0
0P0 Exhaust tailpipe: Rear exhaust tailpipe (standard)
UG0 Hill start assist: Without hill hold control / hill descent control / comfort driving assist
7MQ Emissions standard: Emissions standard, EU5 mod
1D0 Trailer hitch: Without trailer hitch
4UP Airbag: Driver's and front passenger air bag with knee air bag and front passenger air bag deactivation
1E0 Activated carbon canister: Without activated charcoal canister
QE0 Storage compartment package: Without tray areas package/box
7N2 Tray: Spectacle tray/bracket
4S1 Armrests for front seats: Armrests for both front seats
8L6 Antennas: "diversity" window antenna
6XE Exterior mirror setting: Exterior mirrors: electrically foldable and electrically adjustable/heated
EA0 Follow-on warranty: Without subsequent warranty
9GD Interior light in driver compartment: Two interior lights with door pillar switch and switch-off delay
5SJ Left exterior mirror: Left exterior mirror: convex
5RV Right exterior mirror: Right exterior mirror: aspherical
1X0 Drive layout: Front wheel drive
9Y1 Outside temperature display: Outdoor temperature gage
9WR "Multimedia", video/DVD/notebook connection: Installation of audio connection
A8C Equipment levels: Comfort equipment
1KS Brake type in rear: Disc brakes, rear (Geomet D)
J2D Batteries: Battery 380 A (68 Ah)
1ZA Brake type, front: Disc brakes, front
6FB Components with special surface appearance: Body-colored exterior mirror housings
4LB Controls (steering wheels/steering column): Radio control
4M9 Beverage holders: Cup holder
B0N Component part sets with country-specific design requirements: Component parts set, complying with vehicle type for Great Britain, various parts
1S3 Tool kit and jack: Tool kit
1AT Brake systems: Electronic stabilization program (ESP)
4V0 Front passenger seat control: Without front passenger seat adjustment from the rear
0VF Owner's manuals: Information kit in English
9U1 Brake pad wear indicator: Brake pad wear indicator
9T0 Heated washer nozzles: Without heated washer nozzles
7QA CD ROM/DVD/SD card: Without CD/DVD for navigation
7A0 CD changer/CD player: Without CD changer/CD player
QJ1 Chrome package: Chrome work package
C00 General operating permit, alterations: Operating permit, initial registration
0C0 CO2 variant: Standard
3S4 Roof rails/roof load rack: Preparation for roof load rack
3FA Roof insert/convertible top: Without roof insert (standard roof)
1JC Suspension system in rear: Rear shock absorption for sports design
G54 Suspension system in front: Front shock absorption
3X0 Ski bag: Without load-through provision
2G5 Insert for the filling up of unleaded fuel/fuel type: Filler neck module 1 without insert
0EJ Installation differentiation for vehicle components: Installation differentiation for transmission MQ 250 vehicle components
7AL Theft protection system: Anti-theft alarm system, passenger compartment control, backup horn and towing protection
7TB Inserts: Decorative inserts, metallic line
7M3 Scuff plates: Scuff plates in door apertures
7X1 Park distance control: Park distance control
UF0 Electric interface for external use: Without electric interface
0FA Manufacturing sequence differentiation: Standard manufacturing sequence
6A0 Fire extinguishers: Without fire extinguisher
9HA Malfunction display: Without additional malfunction display
VL1 Pedestrian protection: Extended pedestrian protection measures
VF0 Pedal cluster: Standard pedal cluster
6LH Fresh air unit/air outlet: Comfort air outlet
8K8 Headlight control: Low beam assistant with "Coming Home" function
2V6 Fresh air intake for passenger compartment (with particulate filter): Fresh air intake with dust filter
5L0 Front spoiler: Without front spoiler
F0A Vehicle specifications: No special purpose vehicle, standard equipment
3W3 Interior noise suppression measures: Special interior noise suppression
NG0 Top carrier: Without top carrier
8GU Alternators: Alternator 140 A
0YC Weight category rear axle: Weight range 3 installation control only, no requirement forecast
L10 Weight category front axle: Suspension range 10 installation control only, no requirement forecast
TF3 Base engine: 4-cylinder diesel engine 1.6 L 03L.1
3U1 Luggage compartment cover: Foldable trunk cover
6M0 Tie down straps/net/pocket: Without tie down straps/net/pocket
8T2 Cruise control system: Cruise control system (CCS) electronic
9E1 Luggage compartment lighting: Luggage compartment lighting
2B1 Exterior noise suppression measures: Additional exterior noise suppression
5A9 Luggage compartment lining: Luggage compartment lining
G0C Transmission specifications: 5-speed manual transmission
6Y0 Cruise control system and speed limiter: Without cruise control warning system
4Z5 Glove compartment: Glove compartment door with light
6PC Hand brake lever handle: Leather hand brake lever handle
5J4 Rear spoiler: Body-colored rear spoiler
8M0 Rear window wiper and washer system: W/o rear window wiper and washer system
3NU Rear seats: Rear seat bench unsplit, backrest split folding with center armrest
9AK Heating and air conditioning system: Climatronic with impact pressure control free of cfc
8BQ Headlamps: Halogen headlight for driving on the left
6T0 Interior light in footwell: Without interior light in footwell
U5B Instrument clusters: Instrument insert, mph speedometer Great Britain
4L2 Breakaway interior rearview mirror: Dipping breakaway interior rear view mirror
0KA Sticker (customized or special edition): Without stickers and badges
K8L Body style: Notchback - long wheelbase
6SG Luggage compartment floor covering: Trunk floor covering "Comfort"
1W2 Refrigerator: Glove compartment cooling system
3N1 Lids/storage compartments in trunk: Stowage box in luggage boot
0Y1 Climatic zones: Standard climatic zones
4D0 Seat ventilation/massage seat: Without seat ventilation/massage seat
3Q6 Rear head restraints: Three rear headrests
3J1 Head restraints: Height-adjustable headrests for front seats
2LC Fuel tank treatment: Fuel tank with special material treatment (coextrusion)
1Z0 Fuel quantity for initial filling: Initial standard fuel filling
0F5 Fuel systems: Fuel system for diesel engine
3G0 Child seat anchor in front: Without child seat anchor front (ISOFIX)
6KA Radiator grille: Radiator grille
5K5 Paint preservative/transit coating: Transit coating film with additional transport protection measures
FB0 Paint coating: Standard paint coating
3GD Rear luggage/load compartment floor: Plane rear cargo area
L0R Steering system arrangement: Right-hand drive vehicle
1N3 Steering: Speed-related variable steering assist (Servotronic)
7P4 Lumbar support: Manually adjustable lumbar support in front seats
2ZA Steering wheels: Multi-function steering wheel
8RM Speaker installation: 8 speakers (passive)
8Q1 Headlight range control: Headlight-range adjustment
6E3 Center armrest: Front center armrest
9Q2 Multi-function display/trip computer: Multi-function display/on-board computer with check control
3D4 Center console: Center console
EM0 Driver alert system: Without Rest Assist
8Z5 Engine cooling system: Not hot country
D38 Engine specifications: 4-cyl. turbo dies. eng. 1.6 l/77 kW (4V) TDI common rail Base engine is TF3/TN1/TJ1/TI7
7Q0 Navigation device: Without navigation device
8TF Rear fog lamp: Rear fog lights, left and right
8WD Front fog lamp/additional headlamp: Integrated front fog light
7PB Platform group class: Platform group class 2
GR2 Breakdown spray: Breakdown set
1NL Wheel covers: Covers for alloy wheels
CB6 Wheels: Alloy wheels 7J x 16
8AK Radios: Radio
9JA Smoker's/non-smoker's package: Non-smoking package
7K0 Direct tire pressure monitoring system: Without tire pressure warning light
H0R Tires: Tires 205/55 R16 91H optimized rolling resistance
1G0 Spare wheel/breakdown kit: Without spare wheel
3QT Restraint systems, front: 3-point seat belts with tensioner and height adjustment, front
4X3 Side airbag: Side air bag front with curtain air bag
6Q2 Gearshift knob/handle: Leather gearshift knob/handle
0SS Special labels/plates: Labels/plates in English and French
8SA Rear combination lamps: Taillight assemblies, standard design
4E2 Lock operation for tailgate/trunk lid: Tailgate/trunk lid release from inside (electrically)
QI6 Service indicator: Service indicator 30,000 km or 2 year ( variable )
9P3 Seat belt check: Seat belt reminder, electric contact in buckle
3ZM Outer rear seat belts: 3-point seat belts, outer rear
6R1 Gearshift boot/cover: Leatherette gearshift boot
N2S Seat trim covers: Alcantara seat covering
3L3 Seat adjustment: Manual height adjustment for front seats
4A0 Seat heater: Without seat heater
7R7 Side lights: Side marker lights plus additional turn signal lights in exterior mirrors
8QL Key for locking system: Key for locking system with remote control
7L6 Start-stop system/regenerative braking: Start/stop system with regenerative braking
8Y1 Horns: Two-tone horn
S6B Control number (no PR family): Region
5XC Sun visors: Sun visors with illuminated vanity mirror on driver's and front seat passenger's side
7Y0 Lane change assist/lane keeping system: Without lane change assistant
4KC Side and rear windows: Side and rear windows in heat-insulating glass
4B0 Protective side molding: Without protective side molding
3Y0 Roll-up sun screen for rear and side windows: Without roll-up sun screen
7B2 Socket: 12-volt socket in luggage boot
2JV Bumpers: Body-colored bumpers
0BF Rear stabilizer bar: Rear stabilizer
0AF Front stabilizer: Front stabilizer
QN1 Drawers under front seats: Drawer under left front seat
2UC Heavy-duty/sports version: Sports version
8X0 Headlamp washer system: Without headlight washer system
8N1 Windshield wiper intermittent control/ light/rain sensor: Windshield wiper intermittent control
6N0 Mud flap: Without mud flaps
0NB Nameplate set: Nameplate set in base trim
4YD Door and side pockets in rear: Stowage box rear (door and side panel)
2W3 Fuel filler cap/door, locking option: Fuel filler cap remote unlocking
1Q0 Mass damper for steering wheels: Without mass damper for steering wheel
4K3 Door and lid locking system: Radio remote controlled central locking operated from inside and safe securing
B09 Type approval countries/countries with special requirements: Type approval Great Britain and Northern Ireland
5D1 Carrier frequency for radio remote control: Carrier frequency 433.92 MHz-434.42 Mhz
3CA Partition: Without partition
4AT Door and side trim panels: Door and side trim panel in leatherette over the full surface
QV0 TV reception/digital radio reception: W/o TV reception/digital radio reception
1VG Installation parts for engine (engine mount system): Installation parts for four-cylinder engine
1SA Front underbody guard: Without additional front underbody guard
1EX Identification plates: Special identification plate for EC for M1 passenger vehicle
2A0 Delivery equipment: Without delivery equipment
1T0 First aid kit / warning triangle: Without first aid kit and warning triangle
Q2A Front seats: Standard front seats
9W5 Telephone / telematics: Car phone preparation
9TG Additional warning lights: Additional warning lights (door area) front
QG1 Service interval prolongation: Service interval prolongation
7E0 Heat accumulator system/auxiliary heater: W/o heat accumulator/auxiliary heating
4GF Windshield glass type: Windshield in heat-insulating glass
8W1 Washer fluid level indicator: Washer fluid level indicator
8V0 Cigarette lighter: Without cigarette lighter
8FA Second battery/battery installation: Without second battery
0TA Floor mats: Without floor mats
4ZB Decorative trims: Bright moldings
6EA Additional body covers, side: Without additional side body covers (stone guard)
3B3 Additional child seat anchors: Child seat anchor
0RA Ignition/starter switch locking system: Without ignition/starter switch locking system
9M0 Auxiliary heater: Without auxiliary/parking heater
Odd it says
When it has a Bolero 6 cd player with MP3 card slot
and...
under the seat should be something like this under a plastic slot in cover?
BT module
looking from outside...
Edited by olduns
2 hours ago, lichfielddriver said:
Odd it says
Yeah - that is misleading - my cars PR list also has 7A0. And I definitely have a Columbus with a CD Player.
It's really treating the "CD changer/CD Player" as a question that is being answered.  In other words, if you had neither it would say "CD changer/CDPlayer : Without CD changer/Without CD Player"
It would have been clearer if they used the word with, as in "CD changer/CD player : Without CD changer/With CD Player".  That's what they actually mean with that 7A0 statement.
Having a PR code for "9W5" means the car has the wiring and usually the buttons needed to operate a phone but doesn't guarantee that a Bluetooth module is fitted. Do you have any wiring/a connection loom where the carpet is missing under the seat?
The sticker in the boot shows PR codes where an item was optional or where there was a choice of parts available. It's not a complete list.
The easiest way to get the information is to go onto erWin for an hour (about a tenner), enter your VIN and download the 'Vehicle Specific Information'. It will show all the PR codes for your car. I would be wary of putting my VIN into a random pirate website to get the information.
On the 7A0 thing, you have to remember that one of the PR codes' main functions is to tell the production operators in the factory what to fit or not fit during production. So a code telling them not to fit a CD changer is useful in that context. It might also be used to divert the vehicle away from work stations that it doesn't need to visit.
drivers seat right back, cutouts in felt and carpet
mines been robbed int it
Looks like it.
Grrrrr
maybe the wiring has been tucked under the floor after the BT went faulty....
where would the BT hands free microphone be situated?
oh well.........
It's in the assembly that holds the cabin/reading lights, just above the windscreen.
after another look i'd say there might not have ever been one installed?
the holes in the carpet appear to be where the mounting brackets are for the mount plate?
if it stopped working would anyone bother to remove all of that?
the wiring MAY still be there but i wouldn't put too much on it
i shall have a ferkle tomorrow
only found this bit of loom, the felt had been sliced, someone has been busy..
BTW, yes, the mounting plate is gone but it would have given the game away if left or it was needed elsewhere?
anyway...
there are no wire ends or connectors there.
I don't think your car ever had it.
At least it wasn't stolen then.:D
so why 2 pieces of missing carpet and the sliced underfelt?...
Cheaper to make one carpet and use it on all models.
but 1 bit is blanked and another its missing.
