Octavia mk II 1.8T FSI Elegance. (2009)
Does anyone out there have a copy of an original Module 09 (Central Electronics) long code for the above model? Would be most grateful to see the original coding.
It'll depend what options were specified.
What problem are you facing and have you got an autoscan?
Problem is that it reports a right tail light issue. The right tail light works fine, but oddly, the left reversing light doesn't! Whenever I put my lights on I am getting a warning light on the dash. Everything else is OK.
Friday,22,February,2019,09:59:57:59031
	VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
	VCDS Version: 18.9.1.0 (x64)  HEX-V2 CB: 0.4437.4
	Data version: 20190114 DS296.0
	www.Ross-Tech.com
	VIN: TMBBK21Z5A2015448   License Plate: 22 FEB
	Mileage: 163610km-101662mi   Repair Order:
	Chassis Type: 1Z-SK35 (1K0)
	Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 52 56 62 72
	VIN: TMBBK21Z5A2015448   Mileage: 163610km-101662miles
	01-Engine -- Status: OK 0000
	03-ABS Brakes -- Status: OK 0000
	04-Steering Angle -- Status: OK 0000
	08-Auto HVAC -- Status: OK 0000
	09-Cent. Elect. -- Status: Malfunction 0010
	10-Park/Steer Assist -- Status: OK 0000
	15-Airbags -- Status: OK 0000
	16-Steering wheel -- Status: OK 0000
	17-Instruments -- Status: OK 0000
	19-CAN Gateway -- Status: OK 0000
	25-Immobilizer -- Status: OK 0000
	42-Door Elect, Driver -- Status: OK 0000
	44-Steering Assist -- Status: OK 0000
	46-Central Conv. -- Status: OK 0000
	52-Door Elect, Pass. -- Status: OK 0000
	56-Radio -- Status: OK 0000
	62-Door, Rear Left -- Status: OK 0000
	72-Door, Rear Right -- Status: Malfunction 0010
	Address 01: Engine (CDA)       Labels:. 06J-907-115-CDA.clb
	   Part No SW: 1Z0 907 115 F    HW: 1Z0 907 115 F
	   Component: 1.8l R4/4V TFSI     0020
	   Revision: AAH03---    Serial number:
	   Coding: 0203000C18070160
	   Shop #: WSC 73430 790 00000
	   VCID: 38292A440E5DE2B766D-806C
	No fault code found.
	Readiness: 0000 0000
	Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
	   Part No SW: 1K0 907 379 AQ    HW: 1K0 907 379 AQ
	   Component: MABS MK70M          0105
	   Revision: 00H32001
	   Coding: 0016641
	   VCID: 015F87A01D07637F913-8054
	Address 08: Auto HVAC (J255)       Labels:| 5K0-907-044.clb
	   Part No SW: 3T0 907 044 AK    HW: 3T0 907 044 AK
	   Component: Climatronic   H14 0302
	   Revision: 00004001
	   Coding: 0000000000
	   ASAM Dataset: EV_Climatronic A01001
	   ROD: EV_ClimaAutoBasis_SK35.rod
	   VCID: 7BA3F548736B09AFCBF-802E
	Address 09: Cent. Elect. (J519)       Labels:. 1K0-937-08x-09.clb
	   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
	   Component: BCM PQ35  H   103 0537
	   Revision: 00103 AC
	   Coding: 40180A008841B1C04008000000000900010000AE606189605C0440000040
	   Shop #: WSC 26052 210 125136
	   VCID: 323D186CE42108E7589-8066
	   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
	   Component: Wischer 23050  22  0601
	   Coding: 00D7B7
	   Subsystem 2 - Part No: 1K0 955 559 AH  Labels: 1K0-955-559-AG.CLB
	   Component: RLS 090609 05  54  0402
	   Coding: 0730ED
	   Subsystem 3 - Part No: 1Z0 951 171
	   Component: Innenraumuebe  008 5101
	   Subsystem 4 - Part No: 1K8 951 605
	   Component: LIN BACKUP HO  H09 9002
	1 Fault Found:
	00985 - Right Tail Light (M2)
	            010 - Open or Short to Plus
	             Freeze Frame:
	                    Fault Status: 01101010
	                    Fault Priority: 2
	                    Fault Frequency: 9
	                    Reset counter: 153
	                    Mileage: 163525 km
	                    Time Indication: 0
	                    Date: 2013.07.11
	                    Time: 13:49:01
	             Freeze Frame:
	                        Term 15 On
	                    Voltage: 11.85 V
	                        ON
	                        ON
	                        Term 50 Off
	                        OFF
	                        OFF
	Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
	   Part No SW: 1Z0 919 475 B    HW: 1Z0 919 475
	   Component: PARKHILFE 4K  H06 0006
	   Revision: --------    Serial number: 66630916104964
	   Coding: 100001
	   VCID: 40D942A45A8DAA77DED-8014
	Address 15: Airbags        Labels: 1K0-909-605.lbl
	   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
	   Component: Q4 AIRBAG VW8   020 2300
	   Revision: 05020000    Serial number: 0038PD2E1LKL
	   Coding: 0020788
	   VCID: 3D273B50217FC79FB5B-8068
	   Subsystem 1 - Serial number: 6332MSME4656081FG
	   Subsystem 2 - Serial number: 6342MSME475330240
	Address 16: Steering wheel        Labels: 1K0-953-549-MY9.lbl
	   Part No SW: 1K0 953 549 CQ    HW: 1K0 953 549 CQ
	   Component: J0527           053 0111
	   Coding: 0000034
	   VCID: 03538DA8071B716F83F-8056
	Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
	   Part No SW: 1Z0 920 903 B    HW: 1Z0 920 903 B
	   Component: KOMBI         H21 0110
	   Serial number: 00000000000000
	   Coding: 410F00
	   Shop #: WSC 73430 031 00000
	   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
	   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
	   VCID: 34311E741EB506D74A5-8060
	Address 19: CAN Gateway        Labels:. 1K0-907-530-V4.clb
	   Part No SW: 1K0 907 530 AA    HW: 1K0 907 951
	   Component: J533  Gateway   H16 0222
	   Revision:   H16       Serial number: 4020K096060ABF
	   Coding: E9A07F06000202001303
	   VCID: 6695B43C1469A447041-8032
	Address 25: Immobilizer (J334)       Labels:. 5K0-920-xxx-25.clb
	   Component: IMMO          H21 0110
	   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
	   ROD: EV_Immo_UDS_VDD_RM09.rod
	Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MAX3.clb
	   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
	   Component: Tuer-SG         009 2114
	   Coding: 0004854
	   VCID: 76B5E47C44C954C7B41-8022
	Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
	   Part No: 1K0 909 144 H
	   Component: EPS_ZFLS Kl. 69     2901
	   Revision: 00H15000
	   VCID: 2F3B1118FB13250F377-807A
	Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MAX3.clb
	   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
	   Coding: 0004854
	   VCID: 48C95A847EBD923716D-801C
	Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
	   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
	   Component: BOLERO        007 0053
	   Revision: 0A001001    Serial number: SKZ1Z3I8153510
	   Coding: 0D0004000001
	   VCID: 35372370154F1FDF7DB-8060
	Address 62: Door, Rear Left        Labels:. 1K0-959-703-GEN3.clb
	   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
	   Component: Tuer-SG         007 2101
	   Coding: 0000144
	   Shop #: WSC 73430 790 1012544
	   VCID: 323D186CE82108E7589-8066
	Address 72: Door, Rear Right        Labels:. 1K0-959-704-GEN3.clb
	   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
	   Coding: 0000144
	   VCID: 33331D68173B01EF53F-8066
	2 Faults Found:
	00099 - Rear Right Central Locking (Safe) Motor (V164)
	            012 - Electrical Fault in Circuit - Intermittent
	00931 - Locking Module for Central Locking; Rear Right (F223)
	            008 - Implausible Signal - Intermittent
	End----(Elapsed Time: 01:04, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Edited by davecrusty
put in as code.
Feels like a byte 18 issue assuming the wiring and bulbs are in good condition.
Had this always been an issue?
Has the BCM been changed or any chance it's had a none zero value set in byte 18?
I'd suggest using VCP or ODIS-e to check the lighting config (VCDS can't do this) assuming the wiring/bulbs are fine. Someone might also suggest a byte 18 value but generally changing it causes more problems rather than less given the stock value is 00.
Swindon is probably a little far from me but if you're over this way I can take a look.
Thanks mate, original problem caused by some re-coding by a friend, whose laptop buggered up just afterwards so we couldn't see the original coding. That lost me my wipers which I managed to get back. To cut a long story short(ish), after more playing and trawling through coding for other similar vehicles on various forums, I've got to the present state. Have checked the fuses and bulbs and they are OK so can only assume it's the tail end (excuse the pun) of the coding issues I've had.
For davecrusty:
If have seen, that codding for diag. address 09: central electric is following (according to official PR.NR bellow):
48180AB8B05BB1C04008008011000124010000AE626D89605C0440000000
But when your car was in workshop in 2014 year, the codding was following (so small difference - you can try both:
48180AB8B05BB1C040080080110001E4010000AE626D89605C0440000000
Your central control unit 09 supported codding and parameterization as well. I´m able help you only with codding, Hope my information will be usefull.                  Official PR. numbers of  your car: 0A2 0AD 0BD 0EJ 0FA 0HF 0LA 0P1 0SS 0TA 0VF 0Y1 0YE 1A5 1AC 1D0 1E1 1EX 1G2 1JA 1KF 1MV 1N3 1NL 1PD 1Q0 1RX 1S1 1SA 1T0 1W2 1X0 1Z2 1ZE 2A0 2G7 2H0 2JB 2LD 2UA 2W3 3B4 3C7 3CA 3D1 3FA 3G0 3GA 3H0 3J1 3K0 3KD 3L3 3N0 3Q6 3QT 3S4 3SB 3TB 3U1 3X0 3Y0 3Z0 3ZB 4A0 4AW 4B2 4GF 4K3 4KC 4L6 4LA 4N1 4P3 4R4 4SB 4TB 4UF 4X1 4Z5 5C0 5D1 5K5 5NA 5RV 5SJ 6A0 6E3 6FB 6M5 6N1 6PE 6Q5 6SA 6T0 6XP 6Y0 7A0 7AH 7B0 7E0 7K0 7L3 7M5 7MG 7N2 7P4 7PB 7Q0 7QA 7R7 7TK 7V0 7X1 8AG 8GU 8JK 8K0 8L5 8M1 8N3 8NB 8Q1 8QL 8RM 8S5 8T2 8TD 8W1 8WB 8X1 8Y1 8Z5 9A0 9AK 9D0 9E3 9F0 9GC 9HA 9JA 9KA 9M0 9P1 9Q1 9T0 9TB 9U1 9W0 9WR 9Y1 A8D AZ0 B09 B0N C00 C2P D67 E0A F0A FB0 G07 G0K GP3 GR0 HH7 J1L K8B KD0 L07 L0R N0L ND0 NG0 NY0 PJB QA0 QE4 QG1 QJ1 QN1 QR0 QS0 QV0 TE6 U4B UF0 UG0 V0A VF0 VK0 VL0 X2B .
Thank you so much mate. That is brilliant. Hopefully will sort things out when I'm off work next.:biggrin:
Hi MikimMB, I'm afraid that hasn't sorted the problem. I don't suppose you'd be able to send me the original coding for the other modules too by any chance, so I can make sure they are all correct too?
