Breather Pipes?
@Wino they look like a really good idea to be honest. The issue I’ve actually got is the nut on the bracket has come off the bracket and someone has butchered it is the past to the point a 13mm won’t fit and a 12mm is way to small so the entire thing just spins. As the other two gave no real trouble I never thought twice until the entire throng started to spin :dry:.
it will be off tomorrow guaranteed I just need to remember to torque everything up with the jack under the strut so it’s got some pressure this time.
  • Replies 63
  • Views 11.2k
  • Breezy_Pete
    Breezy_Pete
    Email Mike via [email protected] and ask him for a quote for that part number. Include your reg number or VIN so he can treble-check the part number (he'll want to  do so, even though we are pro
  • Breezy_Pete
    Breezy_Pete
    Part number is printed on the hose at regular intervals.
  • Breezy_Pete
    Breezy_Pete
    By the way, (hours) prior to starting the console bush job, squirt some (lots of) penetrating fluid into the far end of the tapped holes in the consoles that the front wishbone bolts go into.  It's no
  • Sponsor
Ah, yes, I've had that too. VW group also do nasty little tricks like making some of those welded-on nuts octagonal, instead of hexagonal, not sure if those specific ones are, but they might be. Can confuse the socket set, or ring spanner.
I had the same issue where one of the captive nuts came away from the bracket. Hacksaw and swearing time :D
And here I was thinking that vw seem more sensible than Vauxhall’s :wondering: haha.
That’s exactly what happened today and what I’ll be doing in the morning. I’m planning on just cutting straight down the middle of th bolt and through the nut.
You can just use standard nyloc nuts, the plate is only there for convenience and locking.
True. Some Fabia ball joint kits just come with bolts and nyloc nuts.
Got to be honest the knowledge some of you guys have about parts astounds me haha
^ Bloody VAG :D
I love how the description is translated into English :D
Guys any suggestions on how to remove the old wishbone from a new console rubber?
it is seriously stuck I tried alsorts to get it out without damaging the new console rubber.
Got know where except for destroying a ball joint which is siezed into the hub so a better ball joint splitter has been ordered.
Slather it in washing up liquid and use a big ratchet strap to pull it out.
You're supposed to leave the ball joint in the hub carrier and just unbolt it from the end of the wishbone.
@sepulchrave  I’ll give it a go with washing up liquid. Yeah I know I’ve got a new wish bone and ball joint to go on. Before I pretty much destroyed it all the rubber was split and dirt was getting in hence the need for a swap lol.
On 23/04/2019 at 18:25, Wino said:
I bought a set of these a while back, and love them.  If you look at a bolt and the exposed end looks like it's going to give trouble as it winds back through the nut/thread, you just spanner one of these onto it with a bit of oil or grease for lube, and it cleans all the rust away nicely.  Wire brushing never quite seems to do enough, in my experience.
https://www.ebay.co.uk/itm/Britool-RHDS3-5-Piece-Metric-Thread-Restorer-Die-Set-Made-In-USA/371216224762?epid=1537051097&hash=item566e3611fa:g:ElUAAOSw0vBUkDy1
That is exactly why I bought a big set of taps and dies from Screwfix when I started getting into difficulties working on my wife's old 2002 Polo back in 2006/2007, running a die down the exposed ends works a lot better than a serious wire brushing, I'd never ever plan to use that set of taps and dies to cut a new thread, but for thread cleaning/dressing it is first class as it includes most of the fine and coarse thread sizes used by VW Group, the tap wrench and die holder are crap, but I have proper tap wrenches and as the "handles/arms" unscrew from the main body of the die holder, they can get into most tight spots, though not quite as tight spots as a genuine set would like you bought.
These lower swivel captive nut plates seem to have vanished from newer cars, it is now nuts and bolts - these "tri nut" plates would have been handy for initial assembly though. I think that the grade of bolts might have changed as well and maybe the size as the spec'd torque has be beefed up from what I remember.
