Injector Removal BMD
Can I put the timing case back on after the head comes off? Will it be held in well enough to put the engine mount back on?
@Tech1e you seem to have done this before. Any advice before I get into it?
  • Replies 80
  • Views 15k
  • Breezy_Pete
    Breezy_Pete
    Move the one from cylinder 3 to another cylinder, and check that the fault moves with it, before spending any money?
  • Breezy_Pete
    Breezy_Pete
    Oh yeah, Schrader valve under a grey plastic cap at the nearside end of the rail.
  • Breezy_Pete
    Breezy_Pete
    With regards painting stuff because there's no engine cover, I think it might be considerably quicker and easier to fit an engine cover instead?  Certainly are available for Polos at least, see photos
1 hour ago, Tech1e said:
The engine mounting bolts to the timing case, the timing case has to come off to get the cylinder head off.
But you can easily bolt it back up once the heads off, only a few minutes work.
Done plenty.
Timing tools essential, use genuine sealer and renew the required bolts.
Yeah, if a support bar isn't available then that's a fair option.
As a rough guide so far I’ve got
Battery off
Air box and pipes out
Injectors and wiring removed
Coil packs, wires and spark plugs removed
Disconnect vacuum pipes and map sensor
Throttle body off
Remove intake manifold
Remove exhaust manifold
Remove serpentine belt
Support engine remove top engine mount
Remove timing chain cover
Rotate crank and insert timing tool
Insert timing tool on cam
Lock cam in place
Remove timing chain
Remove timing chain cam sprocket
Remove cam cover
Remove cam
Unbolt and remove head (check order of bolts)
have i I missed anything or is there anything else that needs removing on this engine to do it?
Whilst the head head is away it’ll give chance to give the engine bay a careful clean as I don’t think it ever has been lol
About right, i'd put the timing tools in first before removing anything. The crank tool is easier with the inlet manifold off though.
Wouldn't worry too much about the order of removing the headbolts, the engine will be stone cold anyway.
Had quite a collection of these at one point.
Cool so you’d get the timing chain cover off and lock everything in place then strip down the rest?
thats pretty cool! I’m debating painting the cam cover whilst it’s off. Seen as there are no covers for these engines at it just looks abit naff lol
Might as well time it up and lock it off first.
Cool forgot put in about dropping the coolant out lol
Edited by mikey362
Obviously make sure the crank bolt is replaced and torqued correctly or the chain will slip and its dead.
Yes I’ve ordered a Haynes so I’ll have all the right torque settings to hand.
Am I to assume that’s happened to vehicles you’ve seen? Lol
Yeah there was a recall on them many moons ago.
Am I right in thinking number 8 in this diagram being the bolt in question?
No surprised there was a recall haha
Edited by mikey362
Yes thats it.
  • Sponsor
There's quite a mess of info about this torque it seems.
Original Skoda info from 2002 says 90Nm + 90° turn, a later edition from 2011 says 150Nm + 180° turn.
I'm sure I've got a document somewhere where both of these appear in different places referring to the same bolt.
workshop-manuals.com seems to have a mixture of the two on different pages and a nasty half-and-half thing where it says - contradicting itself - "150Nm +180° (¼ turn)":
https://workshop-manuals.com/skoda/fabia-mk1/power_unit/12/40;_47_kw_mpi_engine/enginecrankshaft_group_pistons/removing_and_installing_gasket_rings_and_flywheel/
I'm sure I read somewhere that the bolt had changed too, and it appears that N90987302 superseded N90987301 in 2007 , does this correspond to the different torque setting? i.e. for N90987301 - use 90Nm + 90° turn; for N90987302 - use 150Nm + 180° turn?
Edited by Wino
Not sure, I know that 180 turn is an ass, the counter hold tool is huge..lol
  • Sponsor
I bet.
That's a massive difference, they must be completely different bolts, 90 + 90 is not that much more than a wheel bolt, 150 + 180 is huge and horrible, I'd be tempted to use a positive stop for tightening that.
Okay that’s going to get confusing! 😂😦🤣 So are we saying depending which bolt I get depends on how tight I should do it?
Any advice for actually getting it that tight without rotating the crank?
The bolt has been superseded. You can't get the original bolts now, they weren't up to the job and slipped.
Not sure how you are going to stop the crank rotating without the correct/suitable counter hold tool.
I know my mate will probably have one at his garage I just don’t know if it’ll fit. Will have to wait and see lol
I shouldn’t be okay with it but I’ll spend £50 on the right bar if needs be. Still better than paying £750/£800 for someone else to do it haha
Edited by mikey362
Sorry guys next question what sealeants do you recommend for the timing chain case and cam cover?
Also loctite threadlock is it a good call on the crank bolt just to be extra safe?
I personally prefer Blue Hylomar but you may be more comfortable with an RTV Silicone sealant.
It shouldn't be necessary to use threadlock at that tightening torque but you can if you want to be certain of that bolt never coming undone again.
Personally i'd go with genuine sealant as its not scary expensive (different sealer for the timing case, cam cover and the sump iirc). Seen so many bodged up with incorrect sealer and **** oil out everywhere.
Edited by Tech1e
I know it would be different sealant I was just looking at different sealeants for those particular parts but I’ll go for the manufactures stuff if you say it’s more than good enough lol.
Next job is to find some engine paint
