I have just bought a skoda yeti 5L 2011 1.4 TSI. None of the controls on the steering wheel are working. I suspect that the problem might be with the clock spring. Do you know if that can be fixed/repaired or it is mandatory to replace with the new one?
I cannot see a reliable repair being made to a clock spring.
@Yeti5L14TSI - I agree with @Urrell that it's probably impossible to repair (rather than replace) a clock spring.
I am planning to buy an after market topran clock spring because genuine is very expensive. How do you tell which on is the correct one? Or you use vin since oem is difficult to read without removing it
Get the car scanned with VCDS or similar.
It'll show the hardware and software versions of the existing steering module plus it's coding which you'll probably need.
Does anyone know the exact part number for the clock spring for my skoda yeti without having to take it to the mechanic store? Skoda Yeti 1.4 TSI 2011 europe model
European model for skoda yeti. Not UK model
The part number will depend on exactly when the car was manufactured and what options it had.
The best way to check is to either scan it or take it apart to check. It's much better to check before you buy a replacement part rather than afterwards...
Is there a way using vin to find out. I can paste it here
TMBJJ45L8B6028544
A dealer might be able to from the VIN but the parts catalogue states that "before parts order, physical inspection of old part necessary" so I'm guessing it's not always correct: https://skoda.7zap.com/en/cz/yeti/yet/2011-666/9/953-953051/
It's because they used various types of stalk that look identical when fitted but are not physically compatible with each other.
According to the technicians this the correct part OE 5k0953569h. There is a huge discrepency between this one and the others that fit different models. There is a huge difference. This one costs around 300 gbp and the others are as low as 40gbp. Anyone has an idea about this matter?
5k0953569H is a plausible part number for a 2011 Yeti. How did the technician check?
As for the other cheaper parts, it's impossible to tell without their part numbers if they'll work. You need to remember that many versions won't support the MFSW which is why you need the more expensive 'highline' version.
There is a list of part numbers and functionally here: http://wiki.ross-tech.com/wiki/index.php/Steering_Wheel_Control_Module_Versions#Part_Number_5K0-953-569
He did come out wit this number using the VIN. He found out this using his own computer. He did not see the car
I would still suggest you double check using diagnostic equipment or by physical inspection.
The warning is in the parts catalogue for a reason...
I have removed the steering wheel and found the exact part number for clock spring. The price at the dealer is around 350-400. Any ideas for an aftermarket dealer? Attached pic of the part number
Try TPS.
What is TPS?
VAG group trade parts
But make sure that part number is the part you want, coming up for me as a Cruise Control Module.
https://tps.trade/centre-finder
TPS is a shop https://tps.trade/ although that might not be helpful if you're not in the UK.
You could try a car breakers, scrapyard or even eBay.
Yeti5L14TSI what is your location?
Pr
Where is Pr?
1 hour ago, Urrell said:
Where is Pr?
Puerto Rico apparently
I still want to know what a clock spring is
Edited by Gyp
Pristina
Clock spring just google it
