Uninvited passengers
I have tried cleaning my tail lights and remove dead insects from them as well - very limited success, I think I managed to move some of them inside the light (nothing came out, but at least they have been moved within the lamp enclosure and not visible) by use of compressed air and vigorous shaking :D As said, partial success only, some smaller ones are still there. When I had the lights off, took a bit of foam packing (some electronic equipment I bought was supplied in it), cut matching pads for the vents, and glued them around the perimeter of the vents, did not notice any new dead insects since then.
  • Replies 54
  • Views 12.7k
  • If the light with H20 in it is a warranty claim then some with a spider in their cars light might consider giving it a bit of a bath by injection in some water to the light. Obviously nobody woul
  • Manc-Fletch
    Manc-Fletch
    A little arachnid aggro had me removing the tail gate light cluster to retrieve the husk of a long expired eight legged hitchhiker. I got the light off without much effort, but because it’s L.E.D. The
  • Solution
Thanks guys will give it a shot and report back, I’ve seen the plastic trim that can be removed to get to the nuts. However I don’t seem to have anything long enough to get to remove the nut they seem quite deep on the thread.
Will attempt to get something that has better reach.
On 05/06/2018 at 16:55, silver1011 said:
The LED clusters are supposeldy sealed preventing access.
They may be sealed to prevent 'access' but I seriously doubt they'd actually be truely sealed due to the stresses caused by atmospheric pressure changes over time.
Sealed, not air tight…
I had an empty spider skin in one of the tail lights of my Superb. It was there when I bought the car in April 2017 and was still there when I part-ex’d it in Feb this year. The car was only 5 months old when I got it so maybe the spider got in the light while the light was being made, shed its skin and made good its escape before the light was finally sealed 🤣🤣
