Virtual cockpit - change default view?
Thank you so much Ms Grace for your advice and patience.
It has worked a treat. Much appreciated. 😃
  • Replies 88
  • Views 20.4k
  • SashaGrace
    SashaGrace
    It is, under speedometer end I think. Mine is set to version 5 which is 180 mph end and 10 mph increments. I’ll have to look up the coding as I don’t remember from memory, will do so and post p
  • TheWanderer
    TheWanderer
    You're always taking the Mickey.... I see you're in the photo 3rd from left. 😄
  • SashaGrace
    SashaGrace
    Version 5, 10 mph increments and 180 mph end.
Is there anyone here with stock VC or even retrofitted one that has view button? Are you able to uncheck one of the screen and save the settings after ignition off? It’s driving me crazy :)
Why have the option if it’s not working.
in the morning or 10 min later all screens are checked back. Uffff.
maybe there is a settings somewhere with OBD?
Yes.
No option to uncheck views.
I have just bought the OBD eleven but not even tried to plug it in yet ...
Anyone know what Display_Save_CP does? Might be one to have a look at?
I think that you can change the colour appearance with Display farbabgleich, which seems to offer you the chance to enter RGB values into it.
Edited by TheWanderer
Was thinking of component protection. Afraid to change it :)
The color is changed with the ambient lighting. That option does nothing. Tried it already.
There is is option to uncheck views if you long press the view button. It just does not stay put for long.
Tried the Display_Save_CP option and it won't let me access it.
I had another look and to my surprise, I can uncheck views. But they come back next time I get in the car same as you.
I intend to have a play with obd but so far have had zero luck with that (reversing mirror dip no worky) and its on my low priority list now.
Yah. Why have the option if does nothing. Skoda style :)   Too bad. Would have been nice to be saved.
Any Clue what this adaptation does?
IDE14184-Active participant personalization
  • 3 months later...
I recently retrofitted a VC, I managed to change the skin of the speedos to a vRS skin, but the welcome and leaving screen remains with the regular octavia and regular Skoda logo without the vRS start screen.
what is the issue? Can it be coded somehow?
38943805-8380-4AA1-A864-9035F7D70986.thumb.jpeg.af5cf2524353d0e971c731e34d2dbee5.jpegC37B481D-A733-4B42-890E-9A117B6B2793.thumb.jpeg.fe355c8a69b5e2d59b050d46ee1e3ff8.jpeg
Edited by Sava159
As far as I know, the VC only ever shows a 'normal' Octavia :(
As per above. I had one of the first VC on a factory order and I put a video on YouTube showing how it worked. Got challenged all the time on 'why normal car not VRS you liar'. It shows a normal octavia when you shut down as standard🤣
  • 7 months later...
Hey!
Sorry to bring this back to life but has a solution been found to the original problem?
My VC reverts back to the "standard" view every time I restart the car. Gets annoying having to reselect my desired view every time.
Not sure if this is relevant but I have a 3Q gateway on the car.
Edited by razyel
Only solution I found was to turn off the personalisation option. Always have the center dial view (or whatever last used layout was) as my default now.
