I need Bolero Update :-)
Στις 21/2/2021 στις 9:24 ΜΜ, η KARSO είπε:
 Προσεκτικά για πρόσβαση στο Διαδίκτυο στην αναζήτηση Skoda Karoq τη συσκευή μου; Μέρος αρ. είναι 5Q0035840C, το ίδιο είναι H41 και η προσεχουσα έκδοση λογιστικά είναι 0468. Ευχαριστώ πολύ.
Hi @ pab567!!
Please send me an update file for Bolero.
Thank you very much !
  • Replies 1.2k
  • Views 239.7k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Hello,
Hi @ pab567
Please send me to link for update my Bolero MIB II with Mirror Link activated on my SkodaFabia III - 08.2016, as follow:
System information:
Device part number: 5Q0035840B
Hardware: H30
Software: 0353
Media Codec: 3101.0.0.9
Software:
Installed SW train version: MST2_EU_SK_ZR_P0353T
Installed SW MU version: 0353
Part number: 5Q0035840B
Software version: H28.28.81_STD2Plus_EU
Logging:
Current version: MST2_EU_SK_ZR_P0353T (0353)
Update: MST2_EU_SK_ZR_P0353T (0353-1)
HMI Version:
HMI Software: H28.28.81_STD2Plus_EU
Model: GuideModel_28.28.54
Software Base: H28.28.81-201603071429
CGRun Number: H28.28.81-201603071436_STD2Plus_EU_20160307
Skin Editor: 28.24BF3/H28.24.0_Skinner
Skin Model: MSH28.28.68
Skin Build: BH28.28.81-201603071429
Skin Short: Skoda_STD_Skin_B65_S-STD2Plus_EU_3
Skin SPF Filename: Skoda_STD_Skin_B_65_S.spf
I will much appreciated your kindly help,
Thanks,
Daniel
Romania
Speller: (GuideModel_11.10.4)
Text Translation Number: SKTexty_80.17.1_Standard_Gen2_F30
Much appreciated
On 21/02/2021 at 12:22, Oasismad said:
Having issues with crackling via CarPlay and hoping an update might help!
Unfortunately I don't have any formware for your Swing :(
On 25/02/2021 at 20:08, murat2118 said:
Hello, what is bolero update? Is it official update?
Is there any update for
Device: 565035840
Hardware: H41
Software: 0478
thank in advance ^_^
No, this is the most recent software I know.
All others pls check your PMs
On 19/09/2019 at 12:37, pab567 said:
Structure looks OK so I guess you are using the wrong endpoint to start update. Pls do it from the service menu - you enter it by long pressing MENU button.
Hi pab567 i have vw sharan can you help me please update my unit
Pab567 did you send me correct one because my is PO241T and your is PO253T is it same thanks mate
Hi pad567 this error come
Yes, this is correct - your version is 0241, this one is 0253.
Update from SD, not USB
Thank you mate will try tomorrow
Hi mate thanks I updated
Any solution for app-connect ?
Either VW dealer or unit must be hacked.
Any idea how to hacked
Search Internet or find someone who can do it for you...
Thanks mate
Hi pab567
i have vcds but I don’t now how to insert the code I have also code for apple car play do you now how to insert code thanks mate
This can NOT be done with VCDS :(
Hi, I have 5Q0035840A, HW 25 and SW0245. May I ask for the latest sw update? I will plan to go to the Skoda dealer for a SmartLink code, but wanted to install the latest update first. Thanks in advance! :)
hello everyone,
can someone save my nerves? -) im trying to find some info for some time now and still not being successful.
got fabia III 2018 a and samsung 10 lite and i am not able to get the bloody android auto working here in cze.. -)
maybe some firmware update will help? or u got some tip? i can even see the smartlink version in system info..
no map package needed, im used to waze.. just wanna get rid of that holder on my windshield.
20210307_161641.thumb.jpg.a8313438b278cadaa3a79b413ba251db.jpg20210307_161655.thumb.jpg.ed3f3b40f070842df065ccef19350b9c.jpg
thx in advance! have a nice day, stay safe!
Hi can you help me please pab567 i have try to install radio list but is not working do you have software for radio updates thanks and sorry to bother you 👍🏼
@ULFHEDNAAR your unit does NOT support SmartLink, software update will NOT solve it :( You must have glove box unit exchanged.
@Mentt software upgarde will NOT help you, if you have codes then you can use ODIS or VCP to push them to the unit.
Hi @pab567, can you help me with an update for my unit? Thanks!
have anyone update for this Bolero for my Skoda Octavia? Maybe @pab567? 🤞🙂
thanks
Hi, does anyone know if the updates would fix some bugs with sound being delayed or sometimes very long startups?
My details;
PN: 5Q0035842A
SW Version: 0245
Hardware Version: H24
Am I right in thinking the SD card only needs to be FAT32 formatted?
