I need Bolero Update :-)
Hey Pab,
I'm wondering if you can provide me info about my Bolero unit, screenshot attached.  My question is if it's possible to add/activate Smartlink or Android auto support on my unit and if so, how ( I suppose SW update won't do the trick). There is just Mirrorlink option in menu, which is pretty much useless without an outdated selection of phones according the skoda compatibility webpage.
Also, if there is and update for my unit available, what it can actually improve? I have no issues with the unit except I would love to mirror navigation from my phone somehow...
Thanks for your time
  • Replies 1.2k
  • Views 216.6k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Hello!
I am also wondering if I have the possibility to update for Mirrorlink...
May I have a link for an update file?
My car has this system information below.
Thank you so much for your support!!
KonnyK
On 11/08/2019 at 12:19, HingAmHang said:
 🙂  can anyone one here help me I want to update my bolero
pan widget
Hi @pab567
Thanks for all the awesome work you’re doing!
Please can I have the update files for the following;
Thanks in advance!
@Honsa unfortunately this is not possible - you must have th eglove box unit exchanged, if you are interested pls contact me on PM.
@KonnyK unfortunately the same case :(
All others check your PMs
Hello, by reading this thread I understand there should be an update to the Bolero in my MY'15 Octavia 5E (attached), currently in SW 0245 .
I seek to resolve a bluetooth AVRCP issue where song titles are incorrectly displayed (previous song title shown)
Can you please confirm and if possible give me a link?
Thank you!
On 27/02/2020 at 18:47, DavidVI said:
Ignore my last message, all ok now!
I can't thank you enough, my Skoda Surround and Virtual Subwoofer now work! Amazing! Thanks so so much!!!
How did you fix this mate?
Hi @pab567 Can You help me with update of my Bolero Multimedia?
    System description: MU-S--ER
    Identifier: J794
    Hardware number: 5Q0035840A
    Hardware version: H24
    Software number: 5Q0035840A
    Software version: 0241
   Thanks!
Good evening,
Some really helpful info here! @pab567you are the man!
i got my car today and was wondering if it is capable of being upgraded as Mirrorlink isn’t working for me ?
Thank you so much!
Unfortunately there is no newer software version for your unit :(If you want to have SmartLink, Voice Control or Rear View Camera you must replace glove box unit either with Bolero 5Q0035842x or Amundsen 5Q0035874x (x - leter A, B or C).
Thank you @pab567 for your answer. Would you happen to know approximately how much it would cost for a replacement unit and fitting? Am based in the UK. Appreciate your help 👍
Approximately 200 GBP for Bolero and 300 GBP for Amundsen (plus shipping).
Thank you, guess that’s not so bad all told. Will look into it, thanks again for your help 👍
Hi @pab567 - you seem to be the guy to ask, is there a software update I can apply myself to the Bolero unit on my Mk II Octavia? (picture attached)
The issue I'm trying to solve is the unit refusing to read memory cards with lots of folders in, but my old Octavia (which was a year older than this one) read it all no problem so wondering if it's a software issue, or at least to rule that out. (It's literally the same SD card, and tried others too).
Thanks in advance for any help!
Indeed, there is version 0011 - I sent you link via PM - however it requires either ODIS or VCP to have this unit reflashed via OBD.
Thanks very much! Much appreciated. I don't know what ODIS or VCP are (apart from having a quick Google just now) - what's my best course of action? Do I need to buy a gadget to plug into my OBD port and some other software? Cheers.
Could you please help me with the latest software for my Amundsen MIB2?
Partnr: 5Q0035874B (with DAB)
Hardware: H30
Software: 0361
Could someone help me how to activate Smartlink? My Octavia 3 (2016) shows smart link in the menu, but it needs activation. Does anyone some hint how?
Any chance someone sends me an update for mine. Would be greatly appretiated
Partnr: 5Q0035842A (with DAB)
Hardware: H24
Software: 0241
Codec:2101.0.0.8
Thanks in advance
Hello friends, my English is not very good, I have the same device with the same data above, I need to update it, where could I download the firmware ...... it is mounted on a spaceback 2016
Hola amigos, mi inglés no es muy bueno, tengo el mismo dispositivo con los mismos datos de arriba, necesito actualizarlo, ¿dónde puedo descargar el firmware ... está montado en un spaceback 2016?
On 10/08/2019 at 22:49, pab567 said:
@HingAmHang tell me model number and SW version of your unit, you can find it in menu
Hello,
I have recently bought the new Skoda octavia (4th gen 2021)
recently, while driving I suddenly get push update notifications.
I pressed on “UPDATE” and got a screen with two options USB1, USB2.
Can I update the infotainment system firmware using this interface?
Is there any way I can download the firmware file to a USB drive and flash the firmware without taking my car to service?
Note that my VIN number shows there are no updates (Maps) for my vehicle while applying it on the Skoda update portal.
Bolero infotainment,
10 inch screen,
Octavia “Style” model,
VIN# TMBAR7NX3MY125820
and I live in Israel, if that is of any help.
Thanks in advance,
Golan.
Hello,
10 inch screen,
Thanks in advance,
Golan.
On 10/08/2019 at 17:48, HingAmHang said:
Hello Hello 🙂
soory my English is not so good. I come from Germany.
my skoda Dealer say alltime to me.we have no update.
I will update my Bolero.
my car is skoda Fabia 3 11.2015
has one people The Newest firmware for me?
please 🙂
lg..Maik
Me tooooo!
10 inch screen,
Thanks in advance,
Golan.
