I need Bolero Update :-)
  • Replies 1.2k
  • Views 239.1k
  • My friends used to say: Point 1 - Pawel is always right Point 2 - if Pawel is not right then check point 1
  • All check your PMs
  • Sent via PM.   Guys you need to tag me if you want a link as I don;t have time to follow forum on regular basis... I drop me a PM.
Hello!
Is there an update for my system?
If so if you could send it that would be great!
17 minutes ago, JJW23 said:
Hello!
Hold down the Menu/Setup button until you enter the engineering menu, takes about 10 seconds to enter it.
Looking for software train
Hi! This is what appears!
Thanks, this is the software train I was thinking it would be, so I will now send you a PM
Hey! Just wondering if I can get some help with an update for my system please
My phone camera isn't working but I've included the details I found below - let me know if anything else is needed!
System information
Device part number: 5Q0035842A
Hardware: H24
Software: 0245
Media Codec:
2101.0.0.10
When I held down the menu button I got the following:
HMI Versions
Software Base:
H25.14.78-201507211616
CGRun Number:
H25.14.78-201507211621_STD2Plus_EU_20150721
Logging
Current version: MST2_EU_SK_ZR_P0245T (2045)
I can send you 0253 version
Does anyone have a link or can provide me Firmware MHI2_ER_AU37x_P5089_MU1326 (A3).7z the MIBSolution portal is CRAZY slow.
I know this is for an A3, apologies Skoda forum, but this is the closest relevant, most active thread i can find.
Any help appreciated
My current version: MHI2_ER_au37X_p4159
Yes their portal is trash!
I have only these two releases
release = "MHI2_ER_AU37x_P4203"
MUVersion = "1168"
release = "MHI2_ER_AU37x_P5089"
MUVersion = "1326"
I have sent you a PM with link to download 1326 version.
Edited by varooom
Hello,
I have the version below, with mirror link actived is the update activate smartlink ?
Regards.
1 hour ago, miczl57 said:
Hello,
Regards.
You can update to 0138, but it does not make activation of things.
It is for bug fixes etc.
Let me know if you still want the update file.
Hello, the software in the picture in my Kodiaq tool is the first version, I have not had any problems so far.  I want to make smartlink wireless.  is it possible?  is there any new software? I would appreciate it if you could take the time to look at it.  thanks
Diger ekran
10 minutes ago, Serdogan said:
Merhaba, Kodiaq aracımda resimdeki yazılım ilk sürüm, şu ana kadar herhangi bir sorun yaşamadım. Smartlink kablosuz yapmak istiyorum. Bu mümkün mü? yeni bir yazılım var mı? Vakit ayırıp bakabilirseniz çok sevinirim. teşekkürler
Yes 0480 is available should you wish.
1 hour ago, varooom said:
Evet 0480 dilerseniz mevcuttur.
Please, of course I would.  Is it possible to revert to the old version if the new version causes problems?
Sent, and yes it mught be possible to revert
12 minutes ago, varooom said:
Gönderildi ve evet geri dönmek mümkün olabilir
Thank you,
Best regards.
19 hours ago, Serdogan said:
Teşekkür ederim,
Saygılarımla.
Hello, I installed the update without any problems.  I couldn't detect any changes.  Is it normal?  Thanks
Yes, it's not like changing from Windows 7 to Windows 10 where you see big changes.
It will be bug fixes and stability fixes.
47 minutes ago, varooom said:
Evet, büyük değişiklikler gördüğünüz Windows 7'den Windows 10'a geçmek gibi değil.
Hata düzeltmeleri ve kararlılık düzeltmeleri olacak.
Got it, thank you again.
Hello!
3 hours ago, Yurkalviv said:
Hello!
You need to press and hold Menu/Setup button for 10 seconds.  Then look for Software Train value.
6 minutes ago, Yurkalviv said:
SW Train: MEN3_EU_SK370_P0113P
MU: 0469
I will send via PM
On 11.03.2023 at 13:58, Serdogan said:
Anladım, tekrar teşekkürler.
The 565963107 rear seat heating panel works but does not appear to be working on the comfort consumer display.  Could it be missing in the vcds codes?
